Oil leak
Hi guys
Yesterday after 2 hours of driving when came home noticed it's losing oil.
I had a look today and after the car was warm found out it's coming around balancer (ATI) ?. And little bit oil inside cam cover (clear).
so am I f###d???? Or it's some seals or something??
And would it cost me arm and a leg?
it's a 33 GTR , N1 block, Nitto bottom end.
Thanks
Bruce
https://www.sau.com.au/forums/topic/471092-oil-leak/
I am getting 100,00 km water pump(N1) and timing belt kit which includes cam and crank seal . Any other parts I need to get?
Cheers
IMG_0005.MOV
Is it a track car?
If not get a standard pump not an N1
Its easy to think because its a flash 'NISMO' pump its going to be better but not the case for driving around town.
The N1 pump is designed to work at higher RPM
https://www.sau.com.au/forums/topic/471092-oil-leak/#findComment-7838418
  • 4 weeks later...
Just an update:
Car is at mechanics and whole front is off and It doesn't look like its the cam/crank seals or grub screws .
Looks like engine out and head off :mad::mad: ,been told it could be oil pump (8000km Nitto pump) or seals in there somewhere???
Will report back when the leak I found.:blush:
https://www.sau.com.au/forums/topic/471092-oil-leak/#findComment-7841593
I don't know if you have seen the clip or not it was actually dripping out When the car was warm only , oil pressure was normal (started high then dropped when warm unless the gauge is stuffed) when I was looking for a leak, Nitto pump was new when installed .
I will wait  few a days after they check other possible culprits then weigh my options.
Might do my EFR single turbo conversion while the engine is out and save some money ?!!?
What you guys think??
Cheers
Bruce
https://www.sau.com.au/forums/topic/471092-oil-leak/#findComment-7841662
You have to be careful the mechanic isn't taking you for a ride is all. The engine needs to be cleaned, mocked up less belt covers, ps and ac belts off and fan off to be able to warm the car and get a clear indication where the leak Is happening. If they don't know where it's coming from and they don't do that test I would find another mechanic. The leak should be obvious at the rate the oil was coming out on the video.
https://www.sau.com.au/forums/topic/471092-oil-leak/#findComment-7841687
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
