Battery acid / paint damage / Negative cable oxidised
Obligitory I f***ed up and now i'm paying for it.
A year back i went interstate for about 3.5 months and left my car in a mates back yard with a tarp over it.
I'd left a lead acid battery connected thinking that i'd just jump start it when i got back.
Came back and i had a big star shape of rust under the bonnet above the battery and further surface rust below the battery area. Wonderful.
Fast forward a bit, change of address and saved some cash,  and firstly, can't find a competent person that can actually tackle this engine bay damage properly, and neutralise whatever the hell it is on the paintwork. I am assuming it is battery acid/vapor damage but i have no idea what happened.
I've paid a bloke 900$ in Dandenong (Vic) to crack at it and all his paint is just bubbling up and peeling off again. On their warranty card it says they don't cover rust and he doesn't want anything further to do with it particularly.
I've put a brand new lead acid from repco in there and the thing worked for about two weeks and now it won't hold a charge at all. Alternator is giving me 14.4 when i jump it, fortunately i had the alternator reconditioned only 20,000 km's ago.
I've noticed some oxidisation on that main negative lead thats soldered and screwed to the chassis but unsure if this can prevent a battery from charging.
At the end of the day, i think i've got f**ked battery and it has been leaking down its back all over my engine bay again, no idea why, it's 5 weeks old. I plan to replace
it with a dry battery if i can find one that fits.
I'll note that on this R34 the battery compartment was really tight and i pulled out a white tray that used to be under the battery. Is it neccesary or no? I know for example
my Falcon has its own plastic surround for cooling. This one On the R34 is just sitting on the chassis held with a clamp.
Questions i suppose, recommend a type of dry battery thats correct for 34 Gtt?
Can a bad negative connection prevent a battery from charging?
Why do these lead acid batteries keep freaking bubbling over ( amplified sound system in car too much strain?)
Know someone in vic that knows how to tackle rust/acid or an auto elec familiar with fault finding electrics in skylines.
Thanks for your time. I'm aware i f***ed up. cheers
If your tray is Ok and its just surface rust, I would go and buy some steel and brass brushes, plus some emery paper, and a brush for the 4" angle grinder and hit it hard.
Then I would buy some rust convertor/removal, probably in the gel format for your job and apply it and let it eat the rust away then hose off and dry immediately.
Get it nice and clean and dry!!!
I would then apply rust resistant paint undercoat and cover it. What you use for a topcoat is up to you.
While your at it, use the wire brushes, undo your earth strap and clean it up as well.  When re installing don't paint it etc, just leave it bare, except for a spray of CRC yellow contact or a smear of dielectric grease or Vaseline.
I personally wouldn't use a vented battery ever again.  Sealed batteries all the way IMO.
$900, you can do this for $200 and do a better job of it.
You probably need to check the voltage and amperage output of your alternator...could be that your regulator isn't working and the battery is being overcharged???
Damn man, how much battery acid leaked? I ran my battery on 15.3 volts for half an hour and it started to leak. How did the battery acid react to your metal in the engine bay? Below the batter tray mine is white and and the railing by the battery it is white now cause it lost the paint. If a simple sand down, followed by primer and paint enough to fix this issue? youre kinda scaring me now lol. Its only been a week since it happened
Thanks for the input.
Im32fk -  I don't know exactly what happened. Clearly the water in the batteries is nasty and if that drips down its caused the issues under, but i dont understand how its ended up on the bonnet above. The car was left under a tarp and it was very damp out, but the paintwork on this car has always been good. I don't think i'll ever know exactly what caused it.
I do not believe simply sanding it down is enough, to answer your question. The spray painter resprayed my bonnet and sanded back and bogged it 3x before it finally settled.
However I believe after sanding it back as suggested you massage some diluted Bi-Carb soda into the damage that might do the trick. Others might know better though. This is what i'll be trying to do.
Tridentt - thanks for your ideas. It is just surface at this point, just in an awkward spot, particularly on that rail near the engine. God damnit.
My Alternator is giving me a beautiful 14.3 volts, what i have found is that my spray painter has painted the rail and underneath the main negative leads clamp to the frame, so the clamp had a bad earth. I'm not experienced with DC systems but i believe squeezing 14.3 into the battery and having a bad return path probably f**ks them pretty quickly.
I'll sand back underneath the main negative lead clamp and put in a new battery.
Related - i'm having big troubles trying to source a replacement lead. Any ideas on where i can get one?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
