Rb25de+t reliability if done correctly r33 s1
G'day everyone I have a doozy of a pickle. I have built a rb25de+t with good bolt on equipment front facing plenum, big front mount, standard exhaust manifold and a new standard turbo
the problem is we got the car running okay with a few mods like injectors and adjustments of tps sensor
so I took the car to a track day to practice drifting and it was going well until it started to misfire cylinder 6 so we found out that I either have a hole in the piston or blew the head gasket or a valve (I'll have it apart this arvo)
but now I was really happy with the power it put down thinking roughly 200-250 kw and now I'm asking is it possible to beef up a rb25de (a lot cheaper than a det) and get a good tune adjust timing fuel and everything else, I like the power of high compression I'm thinking a thicker good quality head gasket and bolts but unsure how the internals will hold
welcome to all comments??
IMG_1278.mp4
Depends on what you mean by "beef up" if by that you are going to throw a decent set of rods and pistons at it and some head work then the sky (or more likely your wallet / fuel system) is the limit. If you are only planning on the gasket and bolts then you will be limited in what you can throw into it safely and that will also be dependent on your combustible of choice (98 or E85). The goal that you have *should* be reachable with a stock bottom end in good condition and reliably so if you are careful with the tune.
On the bright side keeping your normal DE compression and slightly lower boost might be a good idea to make it as usable as possible - most factory turbo cars these days are shipping with >=10:1 compression for the simple reason that they are trying to make best use of small turbos and create the illusion of a larger motor rather than the laggy huge boot in the pants 1980's turbo experience.
  • Like 1
IMG_1278.mp4
Turns out there is a slight crack in head gasket and was some gunk under the exhaust valve
in thinking of running e85 on a high compression low boost with 250kw in mind apparently e85 likes high compression?
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
