1 minute ago, Got a Pulsar said:
Might be ok, but try the other things first (CRC and coil wrapping) and go from there.
Heaps of info in this site about all these things as they have all been covered many many times over, so have a mad search, read up on R&R, misfires, Fuel pump installs etc etc.
and go nuts!
I know I sure did. :yes:
Spent all day searching haha. How much of the coil do you wrap with electrical tape?
lol I spent years searching.
Never wrapped them myself but I'd go from the bit that goes over the sparkplugs all the way up the shaft to the box!
hmmm... sounds quite suggestive when you say it like that. :D
Haha alright, I'll let you know how I go later this arvo :)
  • Like 1
23 hours ago, vxsr33 said:
Sound's like R&R (rich and retard).
The stock ecu is seeing more air than it's used to so it tries to protect the engine by adding more fuel and retarding the timing. This would make sense since the problem started after you installed the fmic and raised the boost which would result in increased airflow.
This causes a loss of power and the misfiring feeling. You could try clean your AFM with some MAF cleaner and dropping the boost 1 or 2 psi, the problem should go away then.
Are you sure you are running only 10psi and not higher?
22 hours ago, Dose Pipe Sutututu said:
Problem(s) could be from either the Superspark coils (which are rubbish, sorry to be blunt) or faulty OEM ones.
Best to get Splitfire ones or go Yaris conversion or LS conversion coils.
20 hours ago, Kinks said:
Sure, none of us want to spend extra money but if your coil packs are buggered or you spent $400 when you should have spent $600 then the only way out is to spend $600.  Not $500 or $400.
Always buy Splitfires at minimum.  Do not try and go cheaper.  You will only end up opening your wallet again to buy what you should have bought the first time.
19 hours ago, admS15 said:
I wouldn't not doubt the coilpacks in that assumption. I'm not saying that it is your coils either but if they're weak it shows up when boost and power increases.
As above, if buying new coils stay away from the bright coloured ones unless they're the bluey purple ones, otherwise OEM or conversion.
I'm going to entertain the R and R theory.
15 hours ago, Got a Pulsar said:
No I would not as there's still too many variables. Start with the easy and cheap fixes and eliminate them first.
What pump did you put in? Did you feed it a new 12 Volt line via a relay or just use existing wiring?
Some after market pumps don't like old stock wiring.
Check the coils for cracking and wrap the whole long bit to eliminate any arcing if need be.
Update:
have cleaned afm, ran stock boost from inlet piping straight to actuator. Have tried both my sets of coil packs, new plugs. So it can't be rnr or spark related. Any other suggestions? Ignitor?
 LS conversion
  • Like 1
If Series 1 then yes it could be the igniter, could also be fuel pump related or could be faulty AFM or boost leak or vac leak since you've disturbed the piping.
Engine needs Air, Fuel and Spark soooo... keep at it.
Ok I'll look into it
By the ecu thinking the air is going in to the engines and putting the fuel in to suit, only for the air to sneak out a leak and make the engine run rich, or even show enoigh airflow to go into rich and retard.
The ecu doesn't know if the air that goes through the maf makes it into the engine.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
