R33 what power?
Hey guys,
Just wondering what power I'd be looking at with the following mods on my r33 s1;
3.5" turbo back, highflow turbo (hypergear, G3 with high pressure actuator), splitfires, 550cc injectors, z32 afm, r32 ecu nistune, fmic, blitz pod, walbro 255
Any rough guesses from previous experiences or if you know roughly in kw?
thanks guys
https://www.sau.com.au/forums/topic/471756-r33-what-power/
250 - 270 sounds about right on P98, depending on how happy the dyno is that day. Your injectors will stop you going to E85, but if you upgraded them & tuned for E85 you would be looking around 300. Intake piping & cat may cause issues at that power level as well.
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846495
Cat is de-cat (hollow) 3.5" and Intake piping what do you mean? Plenum?
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846496
No, the rubber pipe from the AFM to the turbo - if you still have the stock one it will suck closed at the boost level you need to get over 250RWKW.
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846497
Ok will change that too. I'm only going safe tune so roughly 17-20
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846522
I have literally the same mods aside from the 550s (I have 740s) and I got 230rwkw @ 14psi - I would have gone higher but at the time I had a shitty actuator (which is now replaced).
Your mods will net you 250rwkw-ish as stated but yes, replace the stock intake pipe for a solid one.
Im going E85 in the next few months and all I need is a 460 pump upgrade, flex sensor, fpr for peace of mind and a tune and I should be in the 300 club :3_grin:
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846567
Best bang for your buck way to get to 300rwkw imo. I wish i looked more into going E85 flex before i got a power fc.
https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846572
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
