nm35 aftermarket front grill!
Aftermarket grill to suit nm35 stagea,
Not series 1, maybe series 2 and Autec Axis. I tried on mine series1 and the mounting holes (body clips) line up, the bottom part might need trimming to suit.
Pick up Sth East Melb, $150 negotiable.
  • Like 2
https://www.sau.com.au/forums/topic/471790-nm35-aftermarket-front-grill/
2 minutes ago, iamhe77 said:
Not that I need it, but are you saying that this is for PM35's and not NM35's?
I have no idea what it suits anymore,
Christian in Syd have one and he said it fit his and it's the exact same car as mine.
All the body clip holes line up, just the lower part of the grill seems to be out of place but i'll have a good look again this weekend, it could just be me but it does look like the shape of the series 2 front grill.
Series 2 grill is not as wide as the series 1 grill due to the larger headlights and the bottom section is lower into the bumper (I presume to make up for being narrower).
Just went out to look at mine and it does look more like a series 2 (PM35) grill to me, but can't be 100% certain going off pics.
I think you're spot on here.
The bottom sits lower hence i thought i might have to trim the bumper a bit, so this for PM35?
  • 2 years later...
Hi, do you still have any of these?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
