2 hours ago, ActionDan said:
I can tell you now that when I build my new shed there will be no skids inside it lol
Now... what should I use to coat the floor...
How are you going to get the efames?
I've used the rustoleum coating in parts of the shed, seems to be holding up alright.
5 hours ago, ActionDan said:
Is that an epoxy thing? Epoxy looksl ike hard work to do well.
Last shed I just used a basic concrete sealer with a cerramic grit in it, that was "ok".
yeah epoxy, like anything its all in the prep. Biggest issue I had was the humidty that day stupid high and it dried quicker than I expected.
Prep was remove paint & grease, Citris scrub, water wash, etch, dry over night then coat. I haven't driven on it as other friends have had issues with it peeling parking car son it.
Yeah I'm not doing 140sq m of that...
Car moved under its power back to the big shed. Very happy with the wheels on it finally but will need to get 235/245 for the fronts.
With the sil80 now moved its allowed the 370 to be parked in the garage. Freshly ceramic coated and tint, still no plans to mod it
  • Like 3
Scrolled back and had a man look and couldn't see it..... did you repaint the wheels? if yes where did you get new RAYS stickers, and are they good quality? I just repainted my TE37 and need new stickers
I bought the wheels new when Import Monster got the last run of them.  They can source stickers & centre caps
53 minutes ago, Dose Pipe Sutututu said:
The Nismo Ed. front bar looks sick!
the whole kit is so much better than standard, it has confused a few people thinking its a gtr ?
Just without the box issues and weight 0_0
Yet I still want one for no good reason at all.
If it wasn't for the bland/old looking center console I would have a 2011-2014 one. The facelift 2017+ interior is so much better
23 hours ago, ActionDan said:
I'm talking R35s, are you?
Yep, have a look at the interior differences. When you spend 90% of the time driving a car the interior has to nice especially when spending over 100k
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
