Hello Everyone! Have some go fast bits for sale off my R33 some parts are still new. I won't post interstate but willing to travel and meet in Vic. Located in the S. E Suburbs near Keysbourough. No swaps strictly cash only if you require any additional information you may text me on 0409747507. Thank you. 20171002_164657.thumb.jpg.a720b09fee6089ff76d24646143e04bc.jpg
Brae manifold $700
ARP Headstuds for RB25det *Brand New* $220
Split fire coil packs *Brand New* $600
2000cc Bosch ID Injectors $420
Tomei Type B Valve Springs RB25det $700 *Brand New*
Aeroflow Fuel Rail $130
Twin Plate Ceramic Extreme Clutch $1,200
Haltech Platinum Pro $1400
Also have an R33 manual gearbox that was reconditioned 5,000kms ago new bearings. $1,100
https://www.sau.com.au/forums/topic/472228-r33-go-fast-bits/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
