Model: V36 2009
I had this light on since I bought the car, originally being told it was just the bonnet light... But soon realised it was more than that, but at least it should just be a reset job as the light comes on when removing the front bar even...
So I went to a Nissan dealership to get it reset (as the dealership I bought it from said they didn't have the equipment) to be told that they don't have the tools to do it.
I haven't thought much since, and it went through rego last year fine. But this year it is now sitting at the rego place and he won't pass it with the light on.
Any suggestions? I tried the Nissan dealership again and they said they ca't do imports. I told them that I thought that if they can scan the R35 GTR's they should be able to scan this. He said no they can't.
I am really stuck now as it runs out of rego tomorrow. Anyone have any suggestions?
I read about turning the ignition off and on in the right timing but I think that just send it to diagnostics mode yes, so will still need Nissan Consult hardware/software?
I live in SW Sydney (Camden to be precise)
Edited by Pete_Repeat
Looks like there is hope for me still :) Although I'm not sure if this is guaranteed to work. Fingers crossed.
Also a youtube version, but its for the G37 and its for the SRS airbag
image.thumb.png.0684fd56f3ea6bfa2ae65588b0579220.pngOK so there appears some hope with the
That ought to work for you, unless your ECU has been flashed with the UpRev Osiris. In which case, it either needs the OEM code flashed back to it or the UpRev guys need to get a data dump of your ECU, correct the bug which causes that light to come up and then provide you with the modified code accordingly.
Good luck.
Looks like you might have found the solution, but mate .... NEVER buy a car with a warning light on - you seriously believed them when they told you it wasn't a big deal? Surely they had tried to fix it and failed. Warning lights are there for an extremely good reason. Lesson learnt for others. I would suggest you have an underlying problem that NEEDS to be fixed - even if you follow the steps to reset it, surely it will come back until you actually fix the issue.
You need to find an import friendly Nissan dealer - random Nissan dealers WILL NOT help you - you have bought a grey import and subverted the whole retail stealership tree - Nissan HATES you, and your car. They DO have the tools to diagnose and fix it, but say they don't as they want you to suffer. That said, there are guys who work at Nissan who are occasionally sympathetic to our cause and/or own a Skyline themselves (I know of one here in Adelaide). Or you need to find a decent auto electrician with decent CANBUS compatible hardware and software (V35s/V36s are tricky though).
But like I said - just clearing your code is unlikely to make it go away - you need to fix the underlying issue(s). Hopefullly it is not a big deal, but given you were sold the car in that condition I would suspect something major - think about it - if it was easy to fix/clear the dealership that sold you the car would have fixed it.
Good luck.
Oh. Good... Then turned bad. I'm hoping the Ecu hasn't been flashed then as that sounds like a headache. It's got no aftermarket mods so I'm assuming it's still the stock Ecu code.. Hopefully
I hear you. Hope you're wrong, but fair point.
Occasionally the passenger side window goes up and down when I open the driver's side (like it's meant to when the door opens). They told me that was just a matter of resetting the windows occasionally (the hold down and the hold up reset/calibration) but I'm thinking it's more than that and the system thinks the passenger door is open when I open the driver's door.
Yep, gullible I know. Let's hope it's not an expensive mistake. The car was checked out by an independent assessor with compression checks done on the engine so I'm hopng the  rest of it isn't hiding issues. I've had it for almost 2 years so I think I've found all the problems.
Reason I guess I didn't think too much is that the place is a general import dealer, so assumed they didn't have the proper Nissan consult software..
No doubt about it, they got you good. I have the same model as you and it has never, ever need the occasional reset for the windows. I've had mine for just over five years and have only performed the reset three times because of disconnecting the battery working on stuff.
I would be checking to see what the status is of the passenger door switch when you actuate the driver's door switch. If they're both grounding, that means someone's possibly mucked about with the wiring and got those two door switches working in parallel. I'd be taking a good look at the BCM and its loom for any evidence of tampering/modification.
Anyway, that's a side note. Work through this dash light problem first and then progress to the windows. Good luck!
Amen to that. Precisely why I bought my own Consult knock-off scan tool and software. Besides which, I only really trust myself anyway. :P
Edited by The Max
Quoted too much
1 hour ago, The Max said:
Hopefully the other lesson learned here was don't leave critical shit like that to the last day.
Hadn't thought of that ?. Might stop putting things off, starting tomorrow.
  • 2 years later...
According to the previous owner, the light came on when the importer replaced the xenon lights with halogen ones to pass compliance and then back to xenon after it passed, mines a 2007 model. I tried to follow the on off guide but the light blinked times and then stayed on and didn't turn off after 7 seconds like that guide said
I would have a scan tool run on it to be sure that it's not a legitimate crash recording in the pop-up hood module. If clearing the DTC with the scan tool does not clear the LED and the ECU has not been flashed by an early version of UpRev's tuning code, then chances are the pop-up hood module has some crash data recorded in it.
Replacing headlights will not cause this. My 2009 had the exact same procedure done on it for compliance, with no ill effect and I reverted them back to the factory HIDs myself, again with no ill effect.
Read my post in this thread about the crash module reset process:
It might if they thumped it hard enough to set off a crash sensor, or damaged the wiring, etc.
i had this light monthly because i was always taking the front bumper off and disconnecting the sensors (i ended up moving them inside the crash bar to save time)
It happens when you disconnect the sensor and then start the car.
If you've done the following (below) then pull your bumper off and make sure all 3 sensors are plugged in. If they're not the light wont ever go away.
The procedure to reset Pop-Up Hood manually is:
1) Press twice the Start Button (Do not start the Engine, only instrumentation!)
2) wait about 7 sec, the Pop-Up light goes off ---> Press Start Button immediatly (Switch Off)
3) Press twice the Start Button (Do not start the Engine, only instrumentation!)
4) wait about 7 sec, the Pop-Up light goes off, Flashes 3 times, when goes off press Start Button immediatly (Switch Off)
5) Repeat steps 1-2-3-4
6) Press twice the Start Button (Do not start the Engine, only instrumentation!)
7) The Pop-Up light blinks slowly
? Turn Off
  • Like 1
I would guess that thumping the crash sensor would only trigger the warning if the vehicle was in motion and of course, that would trigger the rams.
Damaged wiring is a possibility but it would take a very conscious effort to achieve that because the sensor wiring doesn't run right up to the HID ballast connector. There's enough wiring up to the ballast connector to allow for the required cut and shut to wire the 12V up to the halogen lamps.
If the dude who worked on it managed to butcher it so bad, bugger me.
The only time I ever encountered this warning lamp without a crash was when I loaded UpRev Osiris into my ECU, there was a slight difference in the JDM ECU code to falsely trigger this DTC. To their credit, they were quick to resolve that for me but I've unloaded it because my dyno guy uses ECUtek instead.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
