Hey guys!
So I pulled out my DE to do a DE+T conversion (Not my first engine swap etc etc) but I've run into a weird issue with the electronics upon putting it back in.
First off, ECCS relay was missing - Didn't have consult plug for Nistune
Next the injectors weren't getting 12v, I ran a switched 12v from pin 24/ignition (where it normally comes from). For what ever reason, it doesn't have continuity on the standard line. OK what ever, just run another one and be done with it.
Now it appears the injectors aren't pulsing eiither.
Have:
  • Tested another CAS
  • Tested ECU grounds
  • Spark, ECU can see CAS
What should I do next? I'm thinking of cutting out the 12v injector switched line as its probably earthing out - but would this cause the injector driver to not pulse grounds to any of the cylinders?
I'd say the whole loom cant be damaged, I can't see any damage and I can't even find where the 12v is broken..
https://www.sau.com.au/forums/topic/472554-no-injector-12v-or-pulse/
R34 GT-V Sedan.
Engine was from this car. Only thing different is turbo, intake manifold (R33 style with all those bits) and R34 Nistune Ecu.
Just doesn't make sense. I need to test the ECU in another car. next.
Ecu tested in another car as working. Cas also tested in another car.
Next is to check continuity back to the ECU loom from the injector plugs.
Running different injectors yes, but they were in my R33 before hand.
With the ignition ON and the CAS removed but still wired into the harness you should hear the injectors firing. Have you done this?
If the Injectors fire during this test the the CAS is not being driven by the shaft.
If the Injectors do not fire and the ECU is fine then there is no connection to the ECU or the +12V.
Michael.
Edited by msammut
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
