Hey guys so yesterday i tried to do a power slide, and kick the back end out. however my back wheels lost traction and it felt like the front wheel saved me. I've been told i need to make a switch to cut off the "bosch" control, which makes the car rwd? If i turn just the VDC off will i be able to kick the back end out a little or do i need to cut/make a switch for the bosch cable?
Cheers
https://www.sau.com.au/forums/topic/472575-vdc/
They are RWD anyway.  I have heard rumours that the VDC off only partially disables VDC, and holding it down for 10sec will turn it off fully.  I have never tested this though.
I suggest you find a suitable location to test it (private property or race track), and give it a try.
Disconnecting the yaw sensor may work too, but it will also throw plenty of warning lights.
https://www.sau.com.au/forums/topic/472575-vdc/#findComment-7857397
Yeah your car will keep trying to save your life.
holding for VDC for 10 sec will turn it off so you can do cool skids. But if the car notices no loss of traction after about 30sec of turn it off some of the life saving computer power will come back on.
So hold for 10sec (VDC turns off), Do a cool skid within 30sec and it will stay off
P.S the 30sec is a guess on how long
https://www.sau.com.au/forums/topic/472575-vdc/#findComment-7857739
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
