So I’m gathering up bits to help the install of my parts
im fitting top mounted 3076r gen2 to a 6 boost, v band setup, rb25 neo
has anyone used this kit for lines ? Or could they possibly advise on what I need, or lengths required
https://m.ebay.co.uk/itm/MAMBA-For-NISSAN-RB20DET-RB25DET-Turbo-Oil-Water-Line-Garrett-GTX3076R-Top-Mount/192419511661?hash=item2ccd18bd6d:g:MiAAAOSwcj1Z9huv
or am I better specifying the lengths to a hose supply shop and making them fit. I gather from Garrett website I need a 1mm restrictor, 4an oil feed, oil drain large enough to freely flow but it doesn’t tell me what size water pipes to use?
cheers
Edited by Eager
Don't use a kit, especially the mamba ones. Buy all the lines and fittings yourself and make it all, it's really not hard.
-4 AN oil feed.
-8 or 10AN oil drain.
-6 AN coolant lines
  • Thanks 1
And what sort of fittings do the lines need on the ends ? Banjo for water in and water out? M10 ? I know the water return end needs a special fitting to fit behind the head
is oil feed from the block banjo too? I know it’s screw in fitting on the turbo
Echoing what's above, I used a mamba/kinugawa kit back a couple of years ago now and it "worked" but wasn't the best. While it didn't leak or really let me down, the lengths didn't really match up with my setup which made it a bit of a messy install.
+1 for buying your own fittings and lines. It's cheaper, generally easier, and you can pick the fittings/colours if you're into that too.
  • Like 1
Whatever you want, whatever fits. Lot of people use thread to -an adaptors out of the block, I used a banjo one for the oil feed on my block because my manifold was in the way. Was going to use banjos' on my turbo core but wouldn't work with the plugs in the way, etc.
Used 200 series -6 for water lines made it up myself at home, same for oil feed but in -4. Pretty easy to cut and assemble in the shed.
Edit: also, water return: it returns both behind the head and infront of it to the radiator return. I and a lot of people have just not bothered to reconnect the one behind the head. Not sure how exactly it returns on Non 26 heads, but for the 26 coolant elbow you can take out the existing tube fitting, tap it with a M10 thread and install a M10 to -6 adaptor which looks really neat.
  • Thanks 1
  • 2 months later...
Is there a nicer method of water return on the rb25 ?
i know the fixed rigid pipe runs into a rubber hose behind the head, just do the same ? With a braided hose and a barb type fitting ? Or what’s the method when doing a whole new turbo install
other lines I’m ok with
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
