  • Replies 49
some schools have it early to get it out of the way... my high school "Epping Boys' High" had ours before exams at Curzon Hall and our sista school (Cheltenham Girls' High) had it after...
we hired 3 stretch limos between 9 couples and did a small tour of the city.
Hey mate, what area are you in of Syd and where abouts is this formal being held? Hmmmm but from memory of doing year 12 last year, usually formal is after HSC (october), but correct me if im wrong???
ours is near the end of september. we are also trying to organise some skylines for ours. (refer to leb's thread in the wasteland)
Nissan Gloria, Gran Turismo for hire:
Turbo Nissan - Fully Sik
VG20DET - Very Fast..
4 Door so easy to get in and out of
Only one registerest in Aust. - Very rare - your mates will be in awe.
Tinted windows - so you can crack on in the back seat with your gal (you pay for any stains on the back seat though)
Back seat is big enough for a threesome - (only if I get to watch and all three are girls)
Very good Price :
$500 per night plus you need to hook my up with one if those Yr 12 girls everyone is talking about :)
Yeah, see about getting a cruise going past the door, plan to arrive just before the last car, make sure every knows that your planning something big and I'm sure that we could russell up a dozen skyzers.
i dunno our marist system is abit :S... but its on the 22nd of septemeber and its at Curzon hall in marsfield dats near like epping and north ryde... but yeh if ne one has sum good skyline rides n are willing drop us off at the formal would be heaps appreciated i live in marsfield too so its not to far :S
I can bring my dad's daihatsu and do ringies out the front 'till the head gasket blows. Only cost to you is half a case of beer (to get me in 'performance mode') and the price of 6 feet of rope (so I can tow it home behind another car).
For real...
Richard
I actually think I might need a ride for my formal aswell :|. My mates Silver GTST got stolen in june and is currently getting fixed, but might not make it for my formal.
:|. My formal's in Baulkham Hills, I live in Blacktown and it is on the 16th of September.
Thanks,
AthlonXP.
For real...
Richard
HAHAHHAHA :( if he doesnt take it up...
ill buy you the case of beer just to see it.....
for real.......
As long as you dont mind me taping that shit.....hahha
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
