Good morning legends.
While scanning yahoo Japan auctions I came across someone selling an RB25de Neo vct solenoid and cam gear as an upgrade for the RB25det Neo... They state that the 25de vct has 30° variability and can give gains to the 25det. I'll attach a screenshot of the auction page.
Can anyone please confirm how many degrees of variability the rb25det s1/2 and rb25det Neo vct system has??
Cheers (:
I wouldn't count on it fitting older 25s.  The advert explicitly talks about ONLY putting it on Neo 25s. (and 26s as a retro with the other stuff you need to do).
I don't know for 100% sure, but I think that the difference between cam front end details on older 25 to Neos means they are not same same.
Yeah for sure man, Im not 100% clear on the difference in vct hardware between Neo and s1/2 either, but I think the solenoid body may be slightly different and I think the keyway on the cam/cam gear is different between the two as well so as you say, probably not interchangeable.
Still though, I'm interested in what the det Neo and det s1/2 vct variability is [emoji848] it could be a nice little gain for very little $$ for a det neo..
The solenoid is different and does not work in non neo engines, the vct is different too,  as GTS boy said they are specific to neo engines. Neo vct cuts in much earlier, from idle, and is active all revs to 5700rpm for turbo and 5400rpm for n/a wheras earlier RB25 ranges are 1050 - 5700 and 1050 - 5400 respectively
Neo and non neo use different actuation methods so solenoids and oil galleries are different. They are wrong to say the pulley has variability if they imply its incremental. It only phases from 0 to 30 degrees and nothing inbetween, this is a big point of confusion with the rb25 vct.
Yep, it is either full on or off there is no variability . Lots of Bullsh*t floating around about this system, its quite basic.
Regardless of NEO or non-NEO the RPM where it is enabled or disabled is 100% configurable if you're not using a PowerFC or Stock ECU.
The window where it stays on should be tuned till when torque starts to decay, of course this is all dependant on what parts have been bolted to the motor.
Generally for me, I will do one run with it turned off and one run with it turned on past max torque ie close to red line and overlay the derived torque graph. The intersection point is optimally where it is turned off. Also once off, the motor will happily take more timing :)
1 hour ago, GTSBoy said:
Also, according to my quick look at Nistune just then, Neo turbo switches at 5400rpm.
I am quoting Tomei and a standard ECU there was no mention of Nistune in his enquiry. I am using Nistune in mine and using the start point at 1050rpm because the VCT internals lasts longer physically if its actuated when oil pressure is higher, they tend to "bounce" internally at idle
Regardless it just doesn't bloody fit so this argument is off subject.
2 minutes ago, GTSBoy said:
Nistune is a standard ECU.  The ROM is sucked out of a real Neo ECU..  I just read the number off the screen.
Huh? Vct isn't active at idle as it makes the idle lumpy due to extra overlap.
never heard of anyone wearing out a vct setup..
  • Thanks 1
I have, and they make a nasty knocking noise when they go try googling nissan vct rattle only 14700 hits
Edited by Rusty Nuts
Yes you have, you answered a similar post back in AUGUST 2015 RB25DET VCT Knocking and i quote you
"Man, I meant the whole vct unit along with cam gear.
I thought it was kind of obvious.
Changing just the actual gear part is a bit pointless, it's the actual vct actuator part of the car gear assembly that needs to be changed"
So whats your game mate
Wow. Got me there. Goes to show I don't remember everything I have said/written 3 years ago.
I don't think it's an issue that needs addressing or accounting for in the tune, shit just wears out.
My game is Q-Bert. Or Pitfall. I am a simple man.
  • Like 2
  • Haha 1
Perhaps on SR20s not RB25s
Different design
Different design
different design sure! Same reason build up of sludge and /or low oil pressure. But hey, past months experience ,if I say its white you will say its black are you 5 years old.
G e e z u z .
I realise now the title is a little misleading... Im mainly referring to weather or not the 25de neo vct gear had more degrees of adjustment over the 25det neo vct gear... sorry I didn't put "neo" after the last "Rb25det" in the topic title.. as I stated in my second comment, I'm aware there are differences between neo ans s1/2 and they aren't compatible..
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
