Hello all,
Second hand gear knob for sale in a used condition. Part number of this item I believe is '32865-05u00'.
If you have any questions please feel free to contact me.
Price: $20
Postage: Willing to post at buyers expense
Payment: Cash on pickup or wire transfer
Regards,
Sean
https://www.sau.com.au/forums/topic/474016-parts/
Hello all,
Second hand gear knob for sale in a used condition. This originally came off my HCR32 which I owned about 12 years ago
I am unsure of the part number of this particular item, however I would say it's OEM due to it's build quality and heftiness.
Price: $20
Regards,
Sean
https://www.sau.com.au/forums/topic/474016-parts/#findComment-7875487
Hello all,
Second hand lowered car ramps for sale. They have served me well for many years and are in good working condition. They pack away quite nicely and the plastic runners are very study. Minor surface rust but nothing major. Always stored in a dry place. Originally they were around $150 brand new.
Price: $50
Postage: If you organise the courier, no problem.
Regards,
Sean
https://www.sau.com.au/forums/topic/474016-parts/#findComment-7875493
Hello all,
Second hand floor mats for sale. With the exception of the passenger mat which is a generic item, the others are original and in good condition considering their age and purpose. Very heavy and the build quality is excellent.
Price: $200
Postage: If buyer organises a courier, no problem
Regards,
Sean
https://www.sau.com.au/forums/topic/474016-parts/#findComment-7875496
Hello all,
Second hand center wheel caps to suit BNR32. Part number is 40342-04U10 (silver variety which suits the standard silver wheels and VSPEC wheels). Three of the caps are in reasonable and usable condition considering their age and purpose, one of them is in worse condition (flaking of paint).
Price: $70
Postage: Willing at buyers expense. I can bubble wrap them for safe shipping.
Regards,
Sean
https://www.sau.com.au/forums/topic/474016-parts/#findComment-7875499
  • 4 weeks later...
  • 3 years later...
    • Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
