G'day chaps,
quick question - my diff is whining and getting a little clunky, looking to replace it. I can get a good stock diff for $250, or thinking of going to a mechanical LSD
Thought about getting a GTR diff, but too hard for me as it invloves swapping alot of parts. Does anyone know anywhere that has one available for R32 GTSt?
Also how do you tell between a aftermarket mech. LSD and a stocker? A few wreckers I have spoken too don't know how to tell the differance, and i am thinking if I can go and have a look, I may be able to pick up a bargain
Regards, Chris
https://www.sau.com.au/forums/topic/47429-aftermarket-lsd-question/
Best way i can tell you about it is to look here : www.cusco.co.jp/english/e_lsd.html
I think from memory Mist (another user on this forum) had a Nismo Pro lsd 2 way kit (brand new in box, with gaskets and oil) I think the kit allowed adjustment for the 2 way as well....i was going to grab it, but lack of funds (have to get turbo & new manifold)
He was letting it go for $1850? i think....damn great buy if you ask me for a new kit already here in Aussie.
Steve did explain before...i think its the shape of cross shaft???...might have to do a search myself :(
Steves explanation
"In the diff centre, there is a key that will be different shapes. It works by pushing plates apart, that causes the clutches to engage. The 1 way will be like a triangle, 1.5 way will be like 2 triangles, but one side will be truncated, and a 2 way will be like two triangles with their bases together (like a square on its side)"
Sorry Steve if i butchered your quote :(
I pulled that of the UAS site, its a modded 33 diff, but if someone could tell if it looked stock or aftermarket it would be a huge help
Hows the diff in your car? is it noisy?
yeah mine is dying slowly, open wheels a bit no and then, crunchy in reverse and clunky in forward gears, so looking for a upgrade
Anyone know if a 33 GTS25T diff would bolt in?
the 33 diff is different ratio, 4.11 vs 4.3x in the 32. Not sure if they would bolt in, but the 33 diff also fits S14 if that is any indication. If its mechanical, you can remove the centre and fit it anyways.
The diff in the photo looks pretty stock to me, have a look on the cusco site for diagrams of how mechanical diffs work.
If the diff is still in its housing, try turning both ends. A viscous diff, you will be able to turn each side of the output ends in opposite direction, a mechanical diff - not a hope in hell. Its easier if its still on the car, then you just jack up one side and try to turn the wheel. If the wheel turns (once again, with some resistance) it is not mechanical, if its almost impossible to turn, but when it does it clunks (slips a little then holds again), most likely a mechanical diff.
Best way though is to pull the back cover off and have a look for the 'keyway' sort of thing :( as per the cusco site. Definately do this if you think you may have found a mechanical diff.
hope that helps
cheers mate, will have a look at a few and see if I can spot one that is not a stockie :(
So say the diff is on the ground, by itself, and I twist each side (where the axles bolt up) in the oposite direction, the stock lsd will allow this quite easily, while a mech. lsd will not allow you to do this?
yeah the viscus std diff will be tight but you will depending on how worn it is be able to twist eash side independenly and smooth, a mechanical will be rough and tight.
33 diff wont fit in 32 but all centres are interchangable.
S13 diffs bolt in and if you find one with a 6 bolt(3 pairs) flange for the driveshafts then you can use s13 shafts which are the smae lange and trade yours in
you could get your stock one and shim it up.
it'll work much the same.
Thats what im getting done to my tired (stock) LSD.
It'll come up close to what a mech would be like, but much cheaper
SOLD...only tell me the name of the place where you are getting it done so i can drop my car over to the free spinning piece of crap re-shimmed :)
That one in the pic looks like a viscous out of a 33, which I understand are unrepairable from my enquiries. I'm just hoping mine is helical so I can get away with getting it shimmed. Post price if anyone gets it done.
I have heard many people mention this, but have never heard of anyone getting it done. If you do, please let all of us know!!!!!!!1 :)
Cheers for all of the replys
Chris
Clint, how sure are you that a S13 diff will bolt in? They are much easier to come across than a aftermarket diff for a R32! So if I find a S13 mech. diff, I'd just need the drive shafts form a S13, and then it would all bolt in?
Cheers, Chris
SOLD...only tell me the name of the place where you are getting it done so i can drop my car over to the free spinning piece of crap re-shimmed :(
Im getting mine done while my car is in for a rebuild.
Ben @ Racepace is doing mine, i've got another 2nd hand LSD and he is just gonna use what he can to shim it right up.
Im sure there are many other places that can do the came thing surely
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
