1996 R33 GTST Series 2
Asking $14,000
Car has 142,000ks
275rwkw and 458nm at 19psi (tuned by trent at chequered tuning)
Overall good condition for age, interior is great, body has some minor dings and marks
Car is listed as repairable write off on the ppsr. Happened back in 07 long before i owned it, repair was done very well and impossible to tell.
Has an idle hunt on a warm start, starts and idles fine from cold start
Mongoose alarm system
350z wheels with 245/40/18s
ENGINE:
Standard Rb25
Hypergear Atr43ss2 turbo
3inch steel intake pipe (havok fab)
Front mount intercooler
NIsmo 740cc injectors
Nismo adjustable fuel pressure regulator
Walbro 460lph e85 compatible pump
Apexi power FC with hand controller
Turbosmart Eboost street40
Z32 AFM
Splitfire coilpacks
3' inch exhaust and dump pipe
DRIVELINE:
Xtreme twin plate clutch
Braided clutch line
Nismo 1.5 way differential
Cusco hicas delete
Gktech rear camber arms
HKS Hipermax coilovers (height and damper adjustable)
Slotted front rotors with qfm pads
INTERIOR:
R32 GTR seats
Defi Water temp gauge with controller
Greddy boost gauge
Fire extinguisher
Comes with 5 months reg, Inspections and questions welcome, however i will be doing the driving until cash is in my hand
20180701_131252.thumb.jpg.33553ba181996d66c7496e5e3b50f034.jpg20180701_131351.thumb.jpg.32a6444ba869dd9e04ca2fc2e60d055d.jpg20180701_131419.thumb.jpg.d6af60055d25523c9cbc0765d56dd10d.jpg
35366234_10216786531554222_3263855792666705920_n.thumb.jpg.210f078fb91d96d9f1ea6cf7430e20e4.jpg
Edited by meatball
adding image
  • Like 1
https://www.sau.com.au/forums/topic/474387-1996-r33-gtst-275rwkw/
  • 3 weeks later...
  • 1 month later...
  • 4 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
