So the other day I took my 34 gtt to work, it’s running a 3076 6 boost power F.C. and z32 etc etc, got to work fine which was a 8 mile basic commute with the last mile a poor road surface
anyway came out of work to drive home and noticed a miss or a bit lumpy, looked down at the wideband and it’s running 18 or so to 1. So very lean. From idle to cruise right through its lean
I went into the power commander fuel adjustment and dumped the fuel in up to 1.3 to get it running smoothly and back to about 15:1 and limped the car home
so first investigation was car seemed low on fuel so chucked a can in, in case it was to low,
also inspected some hoses and noticed the pipe on my z32 afm to turbo was not sealed perfect, it wasn’t off much but I squared it up and tightened it anyway, started the car and it seemed spot on so assumed it was fixed, 15 minute test drive and all was fine so put the car back in the garage
Went to take it a run tonight and reversed it out of the garage and it’s lean again, at idle and through revs do just put it back in the garage,
any pointers ?
its a fairly recent top mount turbo install and map, 300zx fuel filter and a new Walbro was fitted at map time 500-700 mile ago just. Injectors are r35 gtr and also low miles. Voltage still regulates for pump so would like that hard wired,
I want to swap a different z32 in too just to rule it out but any other ideas ?
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/
Oh I know, it was just to get me home, but even I richened it up there was no missfire present
but certainly no missfire is evident, and on the 15 minute test drive the other night it ran perfect. With power F.C. on its map just, no adjustment, I thought the pipe adjustment sorted it as it ran perfect
At idle there tonight it’s stable just lean, not missing
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882524
Ok
so ive had another look around the engine bay and noticed there is a loom that runs along the suspension strut area, off it comes a few things like the o2 sensor, stock boost solenoid plug, it runs over to the afm and then into the wing, maybe headlight?
it seems a bit charred, it’s not completely burnt but certainly has had some heat from the top mount install running fairly close
can anyone tell me is that part of the main loom or is that a piece I could replace easily ?
It might not be at fault but it doesn’t look great
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882556
Sooo done a quick compression check. She isn’t good boys lol.
What’s the official number order by the way?
1 being at radiator, in this case below, 6 at bulk head
Results on cold engine
140-150 odd on 1,2,4,5
3 gets to 140/145 but takes a few extra cranks. 6 is 60 or so and jumped to 70 odd with a little oil in the cylinder.
Going to do a leak down test and bore scope next to decide what is leaking. But the car runs fine, revs fine and has no misfire or nasty noises once the fuel is adjusted on the hand commander.
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7883451
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
