Hello Genies,
I need help,
I have an r33 RB25det series 2 Manual.
After driving for 30 minutes the car begins to stutter hard unless i feather the throttle real soft will feel like it's missing.
If I floor it in neutral it bounces from 3k revs up to 4k and won't hit redline. Feels like the engine is rocking a bit but that's probably because I am trying to rev the balls off it
When driving once it hits 3 k revs the car will start bouncing back and forwards hard and a popping noise will come from the exhaust like it's running rich. This will happen under any moderate or hard acceleration.
If I turn the car off and turn it back on a few minutes later the problem is fixed and the car will run great for the next couple of minutes then the popping and stuttering will resume.
The car drives great when it hasn't been driving for over 30 minutes will hit redline.
I have new NGK iridium plugs -11
And New Osaka Coil Packs which has helped it stutter less
I have re soldered and cleaned the MAF
I ran the ECU got code 33, Heated Oxygen Sensor, I cleaned it put back in. Code hasn't come back also running without o2 still won't rev up
Rescanned got code 44 for ECCS working correctly.
https://www.sau.com.au/forums/topic/474647-rb25det-popping-and-shaking/
Hey thanks for ur guys replys i tried check fuel pump pressure but couldn't figure out how to do it,
Car is fully stock pulled out the sparkplugs have yellow on the tips and the metal screw in part it black, gave them all a clean with break cleaner the stutter persists
They only have about 1500 kms on them
57 minutes ago, NzPeasant said:
Hey am going for a car scan on Friday to diagnose the problem, I will get back and let everyone know what the problem is in case anyone else has this problem thx
Do that ! Where are you taking it as a matter of interest?
Not a bad idea will tee in a fuel pressure guage Ty
Also taking it to a random mechanic shop in Auckland that said they could scan obd1 lol
Will let u guys know the results
Vid attached is me flooring car in neutral revved to 4k the first time I did it
i have a feeling i have a similar issue...with my case my sound just turns into a gruggling sound after 30minutes but the car idle's at perfect 1.1k rpm. The meters are still find, the whiteband reading fine. I don't know...
Some say that i am using water and no antifreeze coolant, causing things to become hot in the radiator and cause bubble. Some say its the thermostat and some say its a blown headgasket.
I know it's not the sparkplugs because i gave the car a service 10days ago with fresh v-power 7 sparkplugs, oil and oilfilter
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
