Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Nothing, except the Quaife rear diff centre of course. Bolts up to any GTR driveshaft axles, except R33 and R34 v spec active diff shafts as they are shorter. Any GTR non active diff driveshafts will bolt up, correct length. This is my spare set I don't need and used same setup. Installed it on my 32 earlier this year when I put Quaife front and rear diffs in.
So the diameters of the shafts are the same and will just fit into the old 32 housing no problems?
Who did you use to install the diffs? If you dont mind me asking, since Award is no longer.
There is a 1mm diameter increase in non splined shaft area from 32mm (30 tooth) to 33mm (31 tooth) and 1mm approx. increase in diameter on spline from 30.9mm (30 tooth) to 32mm (31 tooth). No problems with housing clearance as the increase is all to do with the diff centre bigger spline change. The speed sensor 46t outer and 6 x 1 flange pattern and dimensions are the same.
My father who is a mechanic and has his own workshop did the diff install. Don't have the luxury of 100s of workshops here in Alice Springs like on the east coast. He's pretty much the resident RB26 / GTR guru here in town. Not a lot he doesn't know about them or how to work on them. He is the assembler of the OS giken box for sale here also.
Full genuine Nissan RB26 exhaust / turbo side gasket set - SOLD
Tomei RB26 metal exhaust manifold gaskets - SOLD
  • 4 weeks later...
  • 3 weeks later...
Nismo thermostat - SOLD
Nismo radiator cap - SOLD
Tomei block restrictor - SOLD
ATS clutch discs and pressure plate sold pending payment.
31t rear half shafts sold pending payment.
All PMs replied to.
Fresh 10 plate (standard is 7) modified transfer case is now completed and up for sale. Like new inside and reset back to factory new tolerances. New drive / friction plates, new strainer filter, new oil pump o rings, new retaining and pressure plates, shimmed back to factory 0.2mm - 0.5mm (8 - 20 thou) drum clearance as per required tolerance (around 13 thou from memory).
$1500
Just added for sale Trust / Quaife 3F1 6 speed H pattern straight cut dog box with freshly modified transfer case added for sale.
$8500 ONO shipped anywhere (possibly throw a clutch in there with it with the right buyer).
Going sequential so not needed - make and offer !
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
