Hey guys - So I had issues with my gearbox coming out of 4th gear off throttle.
My mechanic looked at the joint from the shitter into the gearbox and we replaced it anyway but no change.  Then my tuner actually took it apart as he noticed the boot at the bottom of the shifter was gone so that made these quiet again and also stopped some fluid spilling over the top.  He also noticed that the shifter had some parts install wrong and fixed this (grrrr at my mechanic).
This fixed the 4th gear pop out issue but then I was driving along and off throttle again and 5th gear popped out which it has NEVER done.
Now im just confused as to why its changed from 4th to 5th with a correctly installed shifter.  Any ideas?
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/
Either an engine or gearbox mount is sufficiently stuffed to have had the whole driveline move such that the shift lever is getting pushed by the side of the tunnel hole, or, there is a problem with the selectors.  You might have lost a dowel or pin that holds the selector onto the shift rod.  Might be only partway out and wobbly.
I'm sure there are other possibilities too, but failing to imagine them right now.
  • Like 1
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7889712
Has the gearbox ever been overhauled?
Many things could contribute to this, from worn bearings to worn synchros, etc.
Something simple, try flushing the box and popping in fresh fluid. If the box is pretty much on it's way out, then potentially use Redline Shookproof to mask up the problem and drive it till the box goes bang.
(That's what I'm doing).
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7890163
Yeh the box has been overhauled once before (5 years ago).  I was thinking of doing a fluid change but didnt think that will make a difference to it popping out of gear off boost.
I may have an opportunity to get a gearbox (no transferase or shifter which I dont need) for cheap.  Then when this one is out I can rebuild with stronger.
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7890338
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
