EFR 8374, IWG 0.92 A/R.  (slight damage to turbine wheel at edge)
6Boost T4 Divided Manifold to suit IWG.  Ceramic Coated.
Turbosmart IWG75
The lot for $2000ono.  (not looking to sell in parts at this point - it is cheap enough as is).
Guys, be aware that the reason for the cheap price is that the 8374 turbine wheel has sustained some damage.  I have provided a close up of the edge of the fins.  As you can see,  a small piece of something must have gone through it and it has taken 1 to 2mm off the outer edge (on all fins).  This was installed on an RB26/30 as per photos below.
I can say hand on heart that we did not 'know' about this damage. The car has been making the same outright power and I did not notice any lag etc.  The only reason we found it at all was that we removed the exhaust housing to get it ceramic coated and then saw it.   Believing this was a problem (and having some contacts at BW) we sourced a new one anyway and I have held onto this unit as a legitimate spare to throw on if we ever had an issue with the replacement turbo.   We never have, so its been in the cupboard for about 2years now.    We are now also going to bigger setup hence not needing this manifold and it made sense to move the lot as a kit.
For someone looking at upgrading from twins to a single and on a budget, this is good way to net you 600rwhp @1.4bar    (as this one did, even with this damage).  And then you're setup for upgrades later if you feel the need.
Parts 'missing' from it:
  1. You will either need to block the blow-off valve if you are using externals - or source a replacement one. (edit: I might have sourced one, so will confirm).
  2. I have kept the speed sensor, so you can either fit your own or block off.
I'm not in a big hurry to move this - its just clean up time.   I could still use it as a spare, so while I'm open to some negotiation please don't super low ball me.  Its very cheap buying as it is..
https://www.sau.com.au/forums/topic/475990-efr8374-more/
  • 2 months later...
Back up FOR SALE!
Unfortunately - sadly - I've been stuffed around by a fairly active member on here who wanted it - We had several emails and phone calls - even gave me his address to send it to.     Then put me off for a while due to some other bills. (which was fine) .
I held it for him as he said he was still keen - but would need a month or so -  what do you know - now he doesn't return emails or PM's.  Nice.
I even went and found a replacement BOV for it for him - so the only 'missing thing' now is a speed sensor.
I wish people would just man up - if your circumstances have changed - just let me know - I'm not going to bite your head off.
Price drop to $1900
  • Sad 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7903932
  • 3 weeks later...
@GTScotT
Yep - recent Dyno attached.  Yes we wondered about EGT at the time as well - but the general consensus was something small had gone through it. Can't be 100% sure -  Was making around 620 at wheels at the time - didn't have EGT sensors, but wasn't on the bleeding edge or anything.
Do have 6xEGTs now though!  And knocking out 684 on a hub dyno.
(Note we are rolling on boost down low deliberately.)
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7906727
  • 9 months later...
Just now, bri73y said:
Did you end up selling the front diff gears ??
The 4.375?
Nope - still got front and rears (the rear includes a full GT-R diff housing, but no diff).
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7926186
  • 1 year later...
On 09/03/2020 at 12:21 PM, R32 TT said:
The 4.375?
Might be a long shot but would you happen to still have the rear 4.375 gears you mentioned above?
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954203
If you’re chasing diff gears, Neat gearboxes manufactures diff gears for the R200 diff in a heap of ratios.
  • Thanks 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954205
  • 1 year later...
  • 3 months later...
On 27/04/2019 at 5:38 AM, R32 TT said:
Back up FOR SALE!
Price drop to $1900
Might be a long shot, but do you still have this? I'm interested.
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7973405
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
