EFR 8374, IWG 0.92 A/R.  (slight damage to turbine wheel at edge)
6Boost T4 Divided Manifold to suit IWG.  Ceramic Coated.
Turbosmart IWG75
The lot for $2000ono.  (not looking to sell in parts at this point - it is cheap enough as is).
Guys, be aware that the reason for the cheap price is that the 8374 turbine wheel has sustained some damage.  I have provided a close up of the edge of the fins.  As you can see,  a small piece of something must have gone through it and it has taken 1 to 2mm off the outer edge (on all fins).  This was installed on an RB26/30 as per photos below.
I can say hand on heart that we did not 'know' about this damage. The car has been making the same outright power and I did not notice any lag etc.  The only reason we found it at all was that we removed the exhaust housing to get it ceramic coated and then saw it.   Believing this was a problem (and having some contacts at BW) we sourced a new one anyway and I have held onto this unit as a legitimate spare to throw on if we ever had an issue with the replacement turbo.   We never have, so its been in the cupboard for about 2years now.    We are now also going to bigger setup hence not needing this manifold and it made sense to move the lot as a kit.
For someone looking at upgrading from twins to a single and on a budget, this is good way to net you 600rwhp @1.4bar    (as this one did, even with this damage).  And then you're setup for upgrades later if you feel the need.
Parts 'missing' from it:
  1. You will either need to block the blow-off valve if you are using externals - or source a replacement one. (edit: I might have sourced one, so will confirm).
  2. I have kept the speed sensor, so you can either fit your own or block off.
I'm not in a big hurry to move this - its just clean up time.   I could still use it as a spare, so while I'm open to some negotiation please don't super low ball me.  Its very cheap buying as it is..
https://www.sau.com.au/forums/topic/475990-efr8374-more/
  • 2 months later...
Back up FOR SALE!
Unfortunately - sadly - I've been stuffed around by a fairly active member on here who wanted it - We had several emails and phone calls - even gave me his address to send it to.     Then put me off for a while due to some other bills. (which was fine) .
I held it for him as he said he was still keen - but would need a month or so -  what do you know - now he doesn't return emails or PM's.  Nice.
I even went and found a replacement BOV for it for him - so the only 'missing thing' now is a speed sensor.
I wish people would just man up - if your circumstances have changed - just let me know - I'm not going to bite your head off.
Price drop to $1900
  • Sad 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7903932
  • 3 weeks later...
@GTScotT
Yep - recent Dyno attached.  Yes we wondered about EGT at the time as well - but the general consensus was something small had gone through it. Can't be 100% sure -  Was making around 620 at wheels at the time - didn't have EGT sensors, but wasn't on the bleeding edge or anything.
Do have 6xEGTs now though!  And knocking out 684 on a hub dyno.
(Note we are rolling on boost down low deliberately.)
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7906727
  • 9 months later...
Just now, bri73y said:
Did you end up selling the front diff gears ??
The 4.375?
Nope - still got front and rears (the rear includes a full GT-R diff housing, but no diff).
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7926186
  • 1 year later...
On 09/03/2020 at 12:21 PM, R32 TT said:
The 4.375?
Might be a long shot but would you happen to still have the rear 4.375 gears you mentioned above?
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954203
If you’re chasing diff gears, Neat gearboxes manufactures diff gears for the R200 diff in a heap of ratios.
  • Thanks 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954205
  • 1 year later...
  • 3 months later...
On 27/04/2019 at 5:38 AM, R32 TT said:
Back up FOR SALE!
Price drop to $1900
Might be a long shot, but do you still have this? I'm interested.
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7973405
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
