*Wrecking*
R34 skyline midnight blue
*(parts only)* *more parts not listed*
Prices negotiable!
Seats 300 lot front and rear
Seat belts 30 each
Boot lining 80
Bonnet 550
Boot lid 220
Motor ecu & box 1200 sold
Front strut brace 110
Tail lights 400 or 220 each
Headlights 550 sold pending payment
Front bumper 350 sold pending payment
Rear bumper (silver) 120
Front gaurds 200 set fl60(dent) fr140
A.c. fan 25 sold pending payment
Throttle cable 20 sold
Radiator 70 sold
Radiator shroud 30 sold
Locks and keys 100 sold pending payment
Door outer handles 20 each
Door interior trims 30 each
Window switches 15 each
Driver door electrics control 40
Door inner handles 15 each
Center console 60
Cluster (@220k) 100
Dash 200
Glove box 35
Kick panels 10 each
Sunvisors 40 set
Steering wheel with airbag 100
Steering clock assembly 70
Msg for more parts and prices I will respond asap.
No emails please. Scammers reported!
Zaq - 04382three511six
[email protected]
https://www.sau.com.au/forums/topic/476008-wrecking-r34-na-sedan/
  • 3 weeks later...
Staggered and dished 18" speedy inferno rims / mags .
1 has a small buckle on the inside which has never caused me any issues and always balanced up in the 5 years ive used them. Makes any car look and feel instantly better. Good tread.
Front 225 40 18 Tread 80%
Rear 235 40 18 Tread 65%
Would love a polish up.
$650.
Currently on the red ford.images%20(4).jpeg20190215_183518.jpeg20171210_175405.jpeg
  • 1 month later...
  • 1 month later...
Bump!
Cant edit the previous post, need bits just ask.
Speedy Infernos have sold
Still have bits to sell.. make me an offer:
R34..:
Seats
Doors/handles/trims/windows
Mirrors
Glove box
Boot lining
Brakes
Tail lights
Cluster 220k
Strut brace
Seat belts
Interior
dash
ect ect.....
Lots sold
Lots left
Just right.
Clearance prices if i have what you need plus postage!
Also have:
Sr20 coil packs x6 $10 neg each + postage
3.5" hi flow flanged cat $20 + postage
Old r32 front and rear seats front with old covers on the and missing some rail bits , tear in drivers bottom right side and bit of glue on the rear midle upright. Make an offer pick up only.
Rb Wolf 3d v4 plug in with pc usb to serial cable... askin $250 make an offer was gonna use it on my 20 det but decided to stick with stock and piggy back so i dont need it.
20171210_174650.jpeg20171210_175507.jpegIMG_1525384594459.jpeg20190116_131408.jpeg20190202_201402.jpeg20190116_131425.jpeg20181113_205208.jpeg20190226_180723.jpeg20190207_195432.jpeg
  • 1 month later...
  • 1 year later...
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
