Does the oil filter relocator kit make the oil changes easier/cleaner?
shit yeh - photo below, not the best shot of the engine bay but will for viewing purposes. Weather its cleaner im not sure, i havnt done a change yet. but its upside down so i assume a rag or 2 wouldnt hurt.
Hi All,
I have a 1996 R33 GTS-T series 2 - It is my baby, love it!!
It is pink with a purple pearl, i had 20" Chromies on it but they were stolen and my car was vandalised so now i have stockies - I will have it here in Canberra in 2 weeks from Griffith in NSW where i used to live :yes:
So yeah, i attached some pics - hope they work!
I have an aftermarket front mount intercooler and a pod filter - not much atm...
Hi All,
Yeh welcome Melly, nice 33 you have there.. :P
hi all,
Just bought a 93 R32 GTS-T with a RB25 conversion. Apart from gauges, pod and stereo its stock but i have plans for it i.e. intercooler, ECU, 18" wheels, lowered and du luck bodykit....and in time more engine stuff...
havnt posted here in a long while but im bored so here i am.
hi to everyone that does not know me which, i think, is everyone.
1993 r32 gtst
lowered
Veilside front and skirts
3" turbo back exhaust
alpine sound system with tv that doesn't display much
turbo timer
aftermarket steering wheel
and the best thing of all... the word skyline lights up an aqua colour at the back (hope that makes sense)
the rest is stock due to lack of funds
oh and the car is white
question champ how did you get the back bit to light up.??
I just noticed this post lol, isnt it meant to be the RYCO Z145A?
std OK, but if you run an oil cooler or a relocator kit it can be something else. Livo's looks like it's actually a Z55? [3 maybe] when you zoom in, mine is a Z418.
Actually when you look at the Ryco catalogue, the footprint and threads are basically the same [within 0.5mm] for the Z553 range and the 418, only the height is different. The Z145A is different. I don't know if the intended use for each is different.
  • 1 month later...
My new ride, pick her up at the weekend.
R31 GTS series 2 Skyline
1989 R31 GTS Series 2 Skyline: Build No: 055 of 200.
Manual 5 speed RB25 turbo box- h/duty clutch
new bilstein shocks all round-lowered king springs,
Has all the standard Nissan SVD inclusions-
extractors, stage 3 cam, piggy back ecu, adjustable camber re- strut tops, chip, LSD, Scheele bucket seats
sandblasted rocker cover and repainted ( black with red writing/stripe )
BTW: My HR 31 GTS-X is for sale $ 4000.00 and she's yours...
This is a picture of one I owned previously, but you get the idea...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
