Something bad happened.. stalled engine.. won't even turn over.. full charged.. bang noise try start
Hey all
R34 GTT...
Drove to Vic market this morning..
Driving home.. on deceleration toward traffic lights.. going neutral and engine stalls..
Try turn over click click.. click click..
Interesting..
 I have seen very flat battery and bad alternators stall cars...
Anyways brother comes to try and charge me.. try turn over.. still click click..
Smack starter a little and get it to turn over..
Serious metal on metal... Noise..
No oil loss, checked for wet oil in top end by fingering my engine... It has lube for sure..
I dunno.. maybe a rod and snapped or the timing belt...
Can anyone try help me to diagnose the noise? I cannot tell yet without opening anything
My car also died in the city today, Flinders st. Tried to jump it, nothing. Fuel pump was priming, so I thought may be the AFM, unplugged it and it started. Limped it home and starting tearing it apart, tried a working AFM - nothing, front bumper off and checked all intercooler pipes - nothing, fuel rail hose off and turned car into on position - plenty of fuel comes out, pulled plugs - fouled and wet.
Not sure what else, will change plugs tomorrow and hope for the best. Will also check all grounding points.
Can I assume that it’s getting fuel since plugs were wet to rule out injectors and pump?
Anything else I should try?
1 minute ago, ifixedit said:
CAS drive
Curious what ya mean
CAS is driven off the front end of the exhaust camshaft.  Can break.  When it does break, shit stops happening.  Or shit starts happening, depending on your point of view.  Bad noises, for example.
Nice.. gonna borrow friends engine hoist and stand and take a good look..
Might take off front cover first.. look at the timing belt..
Question... Is it possible to remove engine from engine bay without the a.c. compressor??
Don't wanna f**k with the AC.. it works so well
Want to give me a hand as well Hahahaha
Hope you find out the problem.
Yep just unbolt it as well as the power steer pump and put a strap around them to hold to the side out of the way
Edited by NEO25T
Spelling
Thanks NEO
Sadly I actually partially owned a garage in Thailand modding RBs and actually watch a fair bit.. never did a rebuild but will just have a play.. cannot make it worse than it is haha
Maybe I can haha..
I might get the complex stuff like headwork if needed to someone
So anyone is West Melbourne good at working heads
And if need honing done any good places reasonable price?
13 hours ago, ifixedit said:
Thanks NEO
Maybe I can haha..
Any luck today man?
Okay things don't look so sweet.. on first impressions..
Looks like the stalled engine on approach to traffic lights was basically the CAS saying wooooooo something's up!
Looks like the idler pulley for cambelt loose and the bad noise might have been that moving around inside..
Bad bad bad the fact camshafts are not in sync..
Bad bad bad that I tried to keep turning the engine over via starter..
Can anyone weigh in with respect to a starter motor having enough power to bend valves?
I remember even on the half turn the engine was not firing to have a combustion cycle.. so interesting to see if the starter motor would just slightly gouge the pistons..
Time will tell when I go deeper..
Images here in Imgur gallery
https://imgur.com/a/yNRWr3V
Last thing..... Question...
Photo where the balancer pulley is.. since the engine is freely rotating half  to 3 quarters of a cycle... Is the 10mm screw being held by a ratchet bar a typical way to keep the engine crank still while ratcheting off the bolt?
I have ensured there is at least another 30-45 degrees of rotation left from where it's being held..
Or am I suppose to use a longer 10mm bolt and screw it in all the way and let it catch on the engine??
I forgot how the boys use to do this..
I kind of remember using my method haha
Unfortunately that engine is toast by the pics provided. yes the starter is geared low enough to be able to bend valves pretty easily.
How far out of phase are the cams? Can you post a front on picture please.
Continuing to try and start it has definitely done more harm than good.
  based on the little dot on cam gear and marker..
The intake and exhaust would be no more then few teeth out of allignment.. 3-5 teeth out maybe.. and that might be since I released the belt.. and seen it slip.
The main concern in the crank position in relation to the cams.. considering the idler pulley that's no longer mounted would have allowed the crank and cams to misalignment..
I'm going to hazard a guess best chances are... The loose timing belt pulley was jamming the whole thing from turning.. I forced it by forcing the starter motor and heard a terrible grind and stopped instantly.
The grind might have been the pulley.
I'll slowly take her apart..
As far as im able to tell.....Those timing cam gears are completely misaligned if you have that at tdc cyl. The dots on the teeth of the gears should align to the whitelines on the back cover as they indicate where the markers are approximately.
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
