contemplating doing a flex fuel setup on my banana mobile, so was wondering what the brains trust has to say regarding certain brands and what the pre-work requirements are etc to make it a more painless conversion .
i'm aware i'll need to do the pump and the hoses etc, but as to what types of hose, models of in-tank pumps/flow rate etc id like to have some education on, so fire away and hit me with the Pro's and Cons of certain equipment and why...
not looking to make a squillion killerwasps but have a bit more snort when "needed" and the E- sugar juice is available
What power are you trying to support? deatschwerks dw300 is a good e85 rated pump that supports good flow and is 39mm diameter body so is a “drop in” solution. Get like 3m or so of raceworks 400 series push loc hose (e85 rated) and change in tank lines, soft lines from tank to hard line, soft lines from hard line to fuel rail and also the short sections that are in the fuel rail. You will also need a 10 micron stainless filter. Not too sure if the oem fpr is suited for e85. This is my plan for when I get around to it.
Cheers for that, not looking at going beyond 300kw absolute maximum, in fact I'd be stoked to get to 250kw, before I put water to air intercooler on the car was struggling to maintain 175kw with a return flow front mount.
Now with the water to air the car feels a lot stronger so to speak and not fighting itself to make or maintain power if that makes sense?
Drive train wise here's short list of what it's got so far, forged pistons, very light valve work, hypergear ball bearing highflow, 725cc injectors, Nistuned,audi R8 coilpack conversion, 10mm plenum spacer, 140amp alternator, shift kitted auto, 3" front to back exhaust, high flow cat and magnaflow shoosher.
Anything else other than fuel delivery that I need to think of changing or upgrading now?
Im running the dw300 pump with 740cc injectors, stock fpr, making 310rwkw. The above hardware will get you to 300rwkw but not much more. Im running at 90% duty cycle on the injectors with the above combo. You may do a little better with your 140amp alternator.
I would source the flex sensor from a reputable source, i got mine through nistune after getting dodgy one through ebay.
Fantastic, thanks for the info
29 minutes ago, daneprostamobrown said:
return flow intercoolers are shite. i have one and my next upgrade is to a plazmaman or similar. why you running a plenum spacer?
Purely for clearances of the R8 coilpack conversion, they put ke up a long way
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
