My VQ25 has a bad rattle on the fan, and I’ve found it’s coming from the viscous hub/clutch bearing, and found there’s a pretty bad amount of play. The pulley that the belt drives appears fine and solid.
I’m yet to find a local (Christchurch NZ) used part, and Amazon obviously has them for US120 but shipping is outrageous. OEM is ex Japan and $600+.
seems there are no aftermarket parts for this except for the elgrand part from Dayco, but the part number doesn’t match  (and it’s a VQ35) so unsure if that’s compatible.
anyone know if you can pull/press whatever bearing the spindle is on and replace? I haven’t removed yet as I’m using the vehicle so hard for me to inspect myself.
also need to check if the viscous clutch needs checking. Previously I’d had a persistent belt squeal that I couldn’t eliminate and a presumed it was due to excess dust get in there (no underguards currently), but now it occurs to me maybe the clutch going bad might cause a squeal.
any thoughts, parts sources, dodgy fix advice welcome.
cheers
https://www.sau.com.au/forums/topic/476900-viscous-fan-clutch-rattle-play/
It'll likely be the bracket itself. Not expensive. Part number should be 21046-4P100. $80USD from PartSouq (highly recommended, quick shipping from Dubai).
If it is the coupler, that's not too bad from PartSouq. ~$50 in shipping to Australia. NZ shouldn't be much different.
Edited by Akshunhiro
Thanks all for the ideas. Hadn’t heard of partsouq. I’d written off pickapart as they never have Stageas but looking again I’ve found two V35 Skylines that should produce what I need.
Electric fan is a good alternative too.
To clarify the source of the problem, it’s not the bracket or the pulley (or the pump). The coupling assembly (highlighted in the pic) has the fan bolted onto it and does itself have a spindle in the back with a bearing where the viscous magic happens. It’s here there is play and rattle when running.
Not being able to remove and inspect it’s hard to figure out what’s serviceable. I was hoping and would have preferred to service the unit by pulling a bearing and replacing or something along those lines. Nevermind.
Judging by the parts diagram, the water pump is not behind this part but is further over and lower, set into the block with dual orings. Must be a different engine?
33 minutes ago, Akshunhiro said:
Your water pump is inboard and driven off the timing chain. Usually last quite a while. I'd avoid switching to electric thermo's. Clutch is more reliable.
^^^what he said. People changing to electric thermo fans often come a cropper.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
