I'm trying to remove my rear coilovers on my 2000 GT-V, but I'm having a bit of trouble.
I currently have the rear seats out and I'm looking to get at the top bolts of my coils. Problem is I have the parcel shelf in the way, and I can't figure out how to get the C-pillar trim off before removing the parcel shelf. I've been doing some reading that says it'll just pop out if I pull on it. I've pulled on it, but it doesn't seem to budge. I also don't see how I can pull it off when the top seat belt is bolted over top of it. I guess I probably have to remove that. Is this really the right approach or am I missing something?
I've attached some pictures of my current progress and which pieces I'm talking about.
Thanks!
https://www.sau.com.au/forums/topic/477226-r34-rear-coilover-removal/
Armrest part of the rear trim should not need to be removed for this.
C pillar trim should not need to be removed to get parcel shelf out. Certainly doesn't in R32.
Lie on your back in the boot and look up at the parcel shelf. You should see any trim plugs or other fasteners that might be making it stay put.
Hello _scott,
I got stuck on this too because it's hard to see how the tabs interlock.
It's true, pacel shelf is push towards rear windscreen to disengage from c pillar, push down to dismount. It's a snug fit and parcel shelf may be a bit brittle in its age.
Keep us updated on the progress and if you think you need pics for reference I can have a look through my files.
Good luck.
Thanks for the help!
I ended up removing the shelf!
For anyone visiting this thread in the future, this is what I did.
  • Remove rear seats
  • Go into the trunk and find the clips at the top of the trunk that are holding the parcel shelf to it. There should be a few. My clips were blue if that helps at all
  • Once that's done go into the back seat
  • Push down in the area where the C-pillar piece meets the shelf. They should come apart and you should see a slit where the panel slides into the shelf
  • Do the same on the other side
  • Pull! The shelf should remove.
  • Like 1
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
