Good luck getting your hands on one, but if you can then go for it. Any RC car speed control (castle esc) or a fuel lab brushless controller will drive it.
Other option is fuel lab now do a brushless screw pump for in tank use (48403). It's insanely efficient and I suspect it's the same pump assembly as Ti/pierburg with different KV brushless motors for different flow ratings.
A fuel lab and controller is about $1200 au from summit
Would be curious to know if anyone has gone the Fuelab 48403/48402 route for an in-tank setup. I have seen that Deatschwerks is releasing a 340 lph brushless pump as well, which ever integrates best into the stock tank + wiring would be an interesting upgrade.
Let me look into these two brands setup. The Fuelab setup with the CNC housing looks really nice, I wonder if the internals are from Ti Automotive or they started from scratch.
Anyone running them already in their GTRs? I wonder how reliable it is .
Edited by etang789
For comparisons sake, I'm running an L3LM in tank which is a brushed version of the l5lm, it's very quiet and I've tested it to 430lph at 17.5v and 80psi.
The 41403 is totally different as it's a carbon vane pump not a twin screw like these ones are.
Progressive cavity pumps are faaaaar smoother than vane or gear.
I'm going to keep upping the voltage on mine as I make more power (using a boost a pump that is adjustable from 17.5-21v) until I kill it or it runs out of puff. But a brushless pump is about half the current and only needs 13.5v so it's no contest, brushless is way better.
Edited by burn4005
Is Progressive cavity pumps is what Fuelab refer to as Twin Screw Pumps?
Any reason you not switching to brushless?
Sorry, yea i mean twin screw. a progressive cavity is technically a different pump style with a single rotor.
I'll switch to a brushless unit when my fuel pressure drops off with my current setup. could also use an AN6 or AN8 supply line to sqeeze out a bit more flow. im using stock BNR34 lines, stock rb26 rail and a stock nissan filter.
It was an absolute bastard to install the hydramats on the floor of the saddle tank with magnets and the in tank pump on the hangar and I'd rather avoid doing it unless I need to.
its running fine at 500awkw on E80 @ 70% effective duty on Bosch 1462cc injectors. so far.
Edited by burn4005
  • 3 weeks later...
also, note that the L5LM original TI Automotive pump is now available from Ti Automotive aftermarket.
the kit is called BKS1000, and comes with a speed controller, but note that it only runs at full speed as there is no speed control input available.
Link below:
https://walbrofuelpumps.com/catalog/product/view/id/5399/s/ti-automotive-bks1000-brushless-in-tank-fuel-pump/
but the same pump is available from Holley cheaper in this kit
https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_fuel_pumps/carbureted_electric_fuel_pumps/parts/12-767
Edited by burn4005
Link below:
Oh wow good find!
would you say using those aftermarket high flow fuel filter is a must?
  • 1 year later...
If you're a vendor Pm me the site and I'll post about it instead I've searched high and low for one so it's good info.
On 10/5/2020 at 1:57 AM, Wojtek said:
Hello Friends
FYI: E5LM are available, but just don't know can I place website on this page. Thank You.
Edited by burn4005
Hi
   Thank You for this information and possibility. I've sold out all what was available. But for sure will come back next time. Thank You once again.
        best regards
  • 4 weeks later...
Hello again
If You could place links to my websites it would be great.
If You will decide to purchase a pump, shipping costs on my side :)
If it's nesesarry, please modify below informations according rules.
"Hello 🙂
I would like to invite interested private persons and companies to cooperation in range: distribution and purchase of brushless fuel pumps. Popularly named "Veyron pump", E5LM. E4LM, 7.50094.50, 7.50094.00
Purchase possible with invoice or fiscal bill.
Detailed description of the purchase process on the product pages.
Please send your questions to PM or via the website electro-car.pl
Links below:
        thank You "
Hello
Name of article E5LM is designed for Bugatti, because manufacturer can't release the same part number on aftermarket, they (TI Automotive) made a set BKS1000-4 and place inside fuel pump from Bugatti (E5LM) but with other part number (E4LM).
Both pumps have the same flow, pressure, etc. Just outlet pipes are changed, and numbers. In data sheet is showed flow 330 l/h, not HP.
My mistake, sorry. I thought You wrote these pump are only to 330HP, but You wrote these pumps have flow 300 lph.
Explanation: E4LM from data sheet on my website have 330lph at 6 bar.
Popularly information in net tells that E5LM have flow up to 580lph (around), but this flow is at 40PSI (around 2,8bar).
If You will set E5LM on pressure 6 bar, You wil get the same flow. Old part E5LM is replaced by new part number E4LM.
It's exactly the same pump, manufacturer, materials,  flow and pressure.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
