Hi guys,
After mutiple attempts to buy a set of these ive found a guy who will be able to copy these and make some up.... however... i do not have a set.
If anyone knows someone that is selling a set or will lend theres out for a mould i will be happy to pay you for them and perhaps organise a bunch for people who are interested in them.
If anyone knows someone or can point me in the right direction of finding a set will be awesome
Cheers
https://www.sau.com.au/forums/topic/477525-dayz-tail-light-covers/
Two quick suggestions. I'm not going to talk you out of this, but wanted to throw my 2c in.
You could wrap (or even paint) the OEM parts to get the same (or even better) result.
Series 2 Stags have much nicer lights. The pieces on either side of the num plate are chrome. Sorry for this pic of mine, I couldn't find a better one.
Yeah ive got series 2 lights but wanted to have them as they make that part bulge a little more.
Ive considered painting them but dont want to ruin a good set of lights incase i change my mind down the track.
  • Like 1
Fair enough. :thumbsup:
If you're after a bit more bulge to the rear, keep an eye out for one of these. Not many around but do pop up now and then. (Same car as above, after I changed the rear end look up a little)
I do also have a spare set of s2 tail lights collecting dust in the shed if you wanted to try the paint route
stagrear.jpg&key=f8b734652646d7eb25472c17ad0067e338340d6c5e11ee5a939ce85e5853e8ce
I actually just managed to score a set of spare tail lights, but thanks man!
Ill see how they turn out.
Is there actually a factory midwing?
  • 1 year later...
I currently make these 'DayZ Edition' Tail light covers, I have posted my website below where you can purchase!
$150.00 CAD upper and lower set
Prep work is needed. (sanding, primer paint)
Purchase Link Below
https://www.lf-industries.com/product-page/lf-industries-dayz-tail-light-covers
Edited by log88
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
