Well ladies, I have not been on the forum of late, my new job and new baby have meant I have virtually zero time on my hands any more.
The good news is, my R34 Vspec II is just about here, I expect if off the boat in about 1 week. Compliance is all t'ed up and I cant wait. Below are some pics of black beast.
Mods:
Pods, exhaust, HKS in car adjustable suspension, Dry carbon fibre bonnet and WEDS 18" wheels, additional computer module.
I have a PFC, boost kit and INJ on the way as well.
I want to do some other mods but that is another thread.
See out on the roads real soon. I might come on a cruse once I have her complied.
https://www.sau.com.au/forums/topic/47757-ozgtr97v-soon-to-be-ozgtr02v2/
  • Replies 56
I have access to a standard R34 GTR for the airbox, exhaust and a bonnet if needed. I will let everyone know how it all goes. The STD suspension is in the boot so no issues there.
Vspec II's replaced Vspec I's after March 2001.
Compliance will be between $5500 and $7000 depending on a lot of things.
Fatz,
She's a sick looking B!tch, cant wait to be behind the wheel. After almost 4 years with the white one, im really looking forward to drive something new and different. Do you think I will be hard to find on the road? Although there is a lot of R34's around today. Hopefully not to many Vspec II's with carbon bonnet and gold wheels!
I love the Apexi like HUD, see below. This was a nice supprise, will help a lot on track days, as will the bonnet, it will help keep the temp down once I get the KW up!
mesh,
No, I will probably go for the GTSS's after the GTRS experiance, they are not suited to what I need out of my car.
Fatz, Im waiting for a report back on my STD turbo's then we can talk the sphincter of the universe on the GTRS's.
2rismo,
The suspension is, HKS HiperMax II suspension, and you are right they are not in car adjustable, the car did have the Tien in car adjustable at one stage
2rismo,
Yikes... hold your kidneys!! Thats what I have in my GTR and holy bumpy batman!! :cheers:
Prank,
I think I might stay with the STD VSPECII suspension which has to be on the car for compliance anyway. I will wait and make that call once I get to drive the car, I will put a trade plate on it and take it for a spin with the HKS on it just to get a feel.
SW20 GT,
Im bringing it in myself and getting a complier to put the plate on it.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
