Hello,
So at my last track day a couple weeks ago everything was going fine but after a couple sessions all of a sudden when i was pulling into the paddock, my car would not idle at all and had horrible misses below 2k rpm. Everywhere else in the rev range it ran fine an did not break up. Now I've done some testing so I went with the simple stuff first: plugs gapped right, r8 coils(deletes the ignitor). That did nothing. So then i replaced my coolant temp sensor and checked tps voltage, that fixed the idle issue. So I went to check my timing. With the light the first time i checked the marks were so far past advanced that it would have been blown up by now, so I was confused and shut the car off to have a drink. Came back and started it up again to look and now it was a little past the last mark at 30* degrees and was able to get it to 20, with the cas retarded almost all the way it allowed me too. I then went for a test drive and the car ran fine but when pulling it out of the driveway it died. I pulled it in to check the timing and it was the same at 20*. So i went to drive again and got out on the road and got on it, it reved up fine and built boost with no missing, but felt like it had legitimately zero power, and off throttle it gurgled a bit. I replaced my cas and that changed nothing. I'm stumbled at this point. Any pointers??
Thanks for any help.
https://www.sau.com.au/forums/topic/477679-weird-possible-timing-issue-20det/
Check for a slipped crank pulley. The timing marks could be telling you lies.#1 plug out and screwdriver down the hole looking for TDC would be the first step there.
Remember that an RB20 has a switch in the TPS for idle. It doesn't rely on the ~0.45v that the 25s do.
Otherwise, your weird issue is weird and will always be something unexpected!
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
