Gday! Single dad from Vic. I joined bcoz id like to 25/30 my gq. I havea 25 sitting here, have a gt3576 aswell.
Im concerned that i just cant afford the mod, when u start talking trigger kits, vct mod, clutches, building turbo block, building a turbo mani, etc
Any insight would be great, ta ??
https://www.sau.com.au/forums/topic/477781-gday/
10 hours ago, Axed29 said:
Yeah, could just chip away at the build..
Ill build it myself, im just wondering if 25/30 is worth the $$ i geuss
worth it is pretty subjective. different people have different expectations and budgets etc. so it is basically impossible to answer your question.
Having said that i would say an LS swap would make heaps more sense into a Patrol.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910948
I'd say that any RB build into a Patrol is a horrible waste. Big lumpy tank needs a big lumpy motor. LS is smart option for defs. If you must have Nissan, start at VH41 or 45 and work your way up from there. 41 with a turbo on 8-10 psi will be enormously torquey.
See Skid Factory for turbo diesel shenanigans in Patrol. See MCM for turbo VH41 in Stagea.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910964
People have built RB30sfor very little money - just rings and bearings. The trigger kits etc are not essential but you are still talking quite a few thousands and I have no idea what it would take to put it into a patrol.
With about 2.5 tonnes to shift it would take a massive power boost to make it goes fast and then I would think it would be pretty scary to keep on the road.
Do some searching - someone has done this before - don't know how this worked out.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910997
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
