Hey guys, just curious about peoples custom exhaust setups for their VQ35DE cars, specifically G35 Coupe. Due to the cost of importing and extreme lack of used aftermarket exhausts, my options are very slim. After doing a few bolt on mods (Plenum spacer, intake, megan test pipes) I will get a tune. I have not decided if I will bother with headers, but I know after my test pipes I will be needing something better than stock. I know a good exhaust shop that I will get to custom make me one. I will be going with (after tps) HR y pipe, 2.5 inch midpipe with varex muffler for adjustable sound, then continue 2.5 till exit. I know it will be very loud with the varex muffler in open position, which is what i want, but will it be quiet enough with it closed? Or should I add a resonator after the mid muffler? cheers.
https://www.sau.com.au/forums/topic/477825-vq35de-best-custom-exhaust-set-up/
Test pipes and 2.5" til exit will be loud. Custom exhaust will always be trial and error especially with the Varex muffler. You can just add a resonator or xpipe later on if it's too loud for your liking. I personally think with the test pipes that it'll be way too loud but I prefer my exhaust notes to come on when I go above 3.5k rpm.
BTW how are you getting a tune? Have you installed an aftermarket ECU?
Yeah I’m thinking I’ll just go single exit with a resonator and a muffler, don’t want it to be stupid loud and drone, idm the raspy-ness just going for power
Not sure, going to hit up a tuner in my area when the time comes. I asked one shop when I had a v36 350Gt sedan and they quoted $1200 for a tune expecting only 10-15hp!!....
That's he core of Kiwi's question. Have you actually looked into whether the stock ECU can be tuned? I didn't think there were that many places doing flashes on them. Mail order flash tunes are to be avoided.
Edited by GTSBoy
  • 4 weeks later...
Oh yup my car can be flashed and they do offer tunes for this car, getting a tune shouldn’t be a problem just the cost! I have enquired to confirm with the tuners.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
