Hey guys I have come across an issue where I have flushed the motor of my r34 gtt sedan and I have replaced the radiator and thermo but amstill getting to 100 to about 108 110 and I know that its not a good thing but am in the us and do not know what it could possibly be.  its not showing any signs of trouble but I do know it can start evaporating the coolant and mess my motor up please I need some advice.
https://www.sau.com.au/forums/topic/478139-heating-issues/
39 minutes ago, Ben C34 said:
Do you trust the gauge?
What fan are you using? Does it have the shroud in place?
I do trust the gauge but ive installed an intercooler and do not know where the vac line is supposed to go. Stock fan
https://www.sau.com.au/forums/topic/478139-heating-issues/#findComment-7912630
No need to panic. Does temperature come down at highway speeds? If so refitting shroud should help in traffic. As suggested search for how to bleed cooling system on RB engines. In the meantime if you are worried turn your heater on full and wind the windows down!
  • Thanks 1
https://www.sau.com.au/forums/topic/478139-heating-issues/#findComment-7912643
It deis cool down instantly after I drive not even a mile I still have new water pump and shroud with new fans on the way. Running amazing otherwise after 4 yrs.
https://www.sau.com.au/forums/topic/478139-heating-issues/#findComment-7912705
BTW if you are doing water pump that's a good time to do front seal, cambelt, idler and tensioner.
https://www.sau.com.au/forums/topic/478139-heating-issues/#findComment-7912754
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
