When checking the RB25DET Neo of my R34 GTT I noticed that there are two empty holes for bolts and I have no idea if that‘s normal (see image). Is something missing there?
I do have some issues, probably a boost leak or something. But I don‘t know if it‘s linked to this.
The holes are located above the heat shield of the turbo.
Thank you!
https://www.sau.com.au/forums/topic/478485-rb25det-neo-question/
If you need to pull the motor, you can attach the chain to that point and the similar point on the opposite side of the block. Then yoink out the motor with the crane.
Hopefully you never need to do this.
Also not sure if this is their official use but it works well.
  • Like 1
  • Thanks 1
Yep, that's official. nissan even have a part# for the bracket you can bolt there if for some reason a simple bolt in one of the holes isn't suffciient
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
