  • Replies 219
The main advantage is the ability to use a larger oil filter and increase the oil capaciy of the car. Also can make it easier to change the filter and from what I've seen with my install it makes actualy fitting the adapter easiert too!
A thermostat is useless unless you live in the snow, no one has used one.
Why is it an advantage in having a remote oil filter?
The oil filter on a Skyline (GTR especially) is hard to get at, and makes a big mess when you change it (oil goes all over side of engine and suspension). A remote filter "moves" the filter to the strut tower, so you can put an ice cream bucket under the oil filter, and undo it easily and not make a mess.
Why would you need a thermostat?
If you live in a cool climate then the oil going through an oil cooler permanently could result in the oil not reaching operating temperature (ie your oil would always be cold). This can have a nasty effect on bearings and turbos as the oil would be too thick. A thermostat oin the line opens the oil path to the cooler only when the oil termpature is high enough. Works exactly the same way as your car radiator thermostat; keeps you engine at the same temperature.
Have been reading these threads about the oilf coolers and they are confusing me stupid!
Hope this helps.
Helps a great deal thanks. Is there enough for another group buy of 5? I am interested in one for a gtst, with braided lines...
Ask Scotsman. Personally I'm looking at two options for around a grand:
- HKS full kits including cooler, thermostat relocator, mounting hardware
- UAS kits including cooler, thermostat, relocator, mounting hardware, air baffles to direct air (BoostedZed =UAS is getting the production run costs finalised)
Trust33 - Yes I would definately oil the O ring as it will stop it from ripping or overlapping as it is tightened.
Croat - I believe there are three others interested at this stage. when five or more are there we can arrange another buy. No you dont require a thermostat in Australia unless you live at the top of a snow field and you car is naturally aspirated. Turbo cars have no problem getting up to opperating temps on a cold day even when you take it very slowly in the morning. As you know turbos uses exhaust gas to run, which heats oil very quickly.
Here's some pics for you punters!
Also we found out on the track day at PI that if yours is mounted in the guard you need to allow for air to flow through the cooler. I did this by drilling some small holes into the plastic guard. But EMRE had a better solution, which was to replace part of the plastic insert with an r33 gtst guard as this already has factory air flow holes that are pointing down to stop stuff getting into the guard.
I will do this also when I can get a hold of one. As it was worth 10 degrees or more on the track.
Scotsman put me down for 1 of these, I have $$ ready to go.
Oil Cooler Kit without remote filter (Pricing based on enough hose to mount in drivers side front bar.
Blue Pushlock Hose: Retail $550, 15% $465, 20% $440
I will need it in the next few weeks latest to get ready for sandown track day
Guest RedLineGTR
just wondering if anyone has installed one of the oil cooler kits on the drivers side of the front bar?? (GTST) since i will be getting a FMIC that the pipes return to the stock pipes and i have no issues with fitting it on the drivers side, Cheers Rob
Bugger it put me down for the group buy. I have already spoken to the boys at meridian and they are fitting it.
Cooler, braided, remote. Retail $1025, 15% $875, 20% $825
Can I pay meridian directly, as they're fitting for me?
Cheers Chris
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
