We should say doing clutch thing (decoupling engine) or doing clutch thing (connecting engine to gearbox) to remove confusion..
Happy to help, and I'm out
  • Like 1
35 minutes ago, BK said:
Yes I have had the "what's wrong with your car look". If that's the reason not to get a multiplate your in the wrong car. Right ?
People thinking my car is broken is fine with me!
Same. That's my point dude. Are you really going to not buy a twin / triple because someone you don't know and knows jack shit about cars would think about your clutch noise ?
  • Haha 1
16 hours ago, BK said:
released was a shit term to use. I could use the term released as my foot not on the clutch, for example (clutch pedal is released
Dude, your opinion is that released is a shit term to use - but your opinion is just that, no-one else cares. I said clutch is released, you interpreted that as clutch pedal is released - surely you know the difference between a clutch and a clutch pedal.
The attitude was becuase your post added nothing of value to the conversation, but you had to say it anyway - do you work for the government? You saw an opportunity to call someone out, and couldn't resist.
Anyway, if you haven't actually got something uselful to say, I'll just ignore you.
Far out man. No I don't mean anything like that. I'm not trying to call anyone out. Originally it was just when do mean it is making a noise, that's all. Clutch in or out, that's it.
Can't we all just get along please ? No need to be so angry.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
