Hello,
I have a R34 GT and my brake pedal has no pressure. I have replaced my master cylinder with a used one from Ebay and same result. When I pump the brakes it hold pressure for a few seconds with car on.
I can only find refurbished parts, is there a way I can use new brake master cylinder from another vehicle?
Edited by skylinebey
https://www.sau.com.au/forums/topic/480073-r34-gt-master-cylinder-replacement/
If you take your M/C to a brake specialist they should be able to repair it with new seals. If it is badly worn and pitted they can resleeve it. If you can find a new one it is likely to be up around $400 -$500.
Have you checked out the supplier below? They have a couple of items they say will fit the R34.
https://www.ebay.com.au/itm/OEM-QUALITY-Brake-Master-Cylinder-For-NISSAN-280ZX-S130-Part-JB1362/172450975591?fits=Plat_Gen%3AR34|Make%3ANissan&hash=item2826e10f67:g:KmcAAO
Or try Amayama...I have previously bought an R33 M/C from Nissan in NZ but I believe most Aussie dealers will not get one for you.
Thanks,
This is my second refurbished MC from eBay and same result.
I tried the mechanics here and they don't have any repair kits.
So I will have to look on eBay for a resLeeve kit.
Does the brake booster go bad?
If so, how to I check ?
Thanks again
13 minutes ago, skylinebey said:
Thanks,
Thanks again
The one I listed is supposed to be brand new, not refurbished. Your average workshop will not do the work -  you need a brake specialist. You will  not likely find a kit on Ebay.
Brake boosters can fail but you would have the opposite problem - a lack of assistance, not the pedal sinking to the floor.
Have you checked each corner of the car for leaking brake fluid?
Don't buy "refurbished" MCs from eBay.
You don't want a kit. You don't want a mechanic. You want a brake specialist, exactly as Kiwi said. You take YOUR MC in there and they fix it, and they give you a warranty. If you take it home and install it and the pedal is still f**ked, it is very much more likely that you've got another problem, not that the MC is still faulty. And then you start to think about your caliper seals, etc.
They can and do, but that leads to a hard pedal, not a mushy pedal.
I have replaced the original calipers with the upgraded calipers from the R34GTT model mines was the GT  NA.
Presumably with used units. You need to check each wheel.
Another possible source of  new M/C is Kudos Motorsport.
I presume you have replaced the old fluid with new and properly bled the system?
The old caliper had a frozen piston and rusted .
I cleaned up the piston and resealed that caliper and the brakes became spongy.
So I then replaced with the bigger Gtt calipers and
Pedal was still spongy?
I then checked the Gtt caliper to see if there was a leaky seal. The was no leak.
But still spongy , Then I thought the larger caliper working with the original MC was causing the spongy .
So thats how I got to the MC being the problem... because it happened when the Orignal caliper went bad.
I even replaced the ABS unit. Still same response.
8 hours ago, skylinebey said:
What is the proper procedure bleeding with a dry ABS?
Thanks.
Sorry I don't know. I have always made sure to keep air out of the ABS unit. Some cars have small bleeder screws, some need a pressure bleeder and for some you need a scan tool to open and close solenoids. The answer may be in the workshop manual or hopefully someone else may be able to help.
I am 100% sure that the procedure for bleeding the ABS has been posted before. Search, and ye shall find.
By the way, it is a complete prick of a task.
Also, when it comes to (vital safety) stuff like brakes, if you really do not know enough to solve your own problems, you should really consider using a professional to fix them. Just sayin'.
My experience is with R32 GTR, being 10 years newer there may be easier ways to do it in an R34
It is a complete prick of a task.
Ultimately I pressure bled the system - 4 calipers (8 nipples), in order of furthest to closet to the master cylinder (so RR, LR, RF, LF) and then the 2 nipples on the top of the ABS.  Of course, since there was air in the ABS unit it was unsatisfactory, and since this was happening during a rally I needed to deal with it. So, after each stage I bled the ABS again (during the stage each time you trigger the abs all the little solenoids and things open and close moving air through the system).  Still sucked. After the event I then did a full bleed and it came up good
So, pressure bleeding makes it much easier because a single person can do it with less effort, and the ABS didn't come good simply by bleeding it static, it needed to be cycled a whole bunch of times before the air all moved out.
Hopefully R34 has some sort of ABS bleeding mode you can put it in instead of having to drive it and activate ABS over and over again...
Thanks
i live on an island , finding mechanics that specialize in just brakes is difficult. So you learn how to do things yourself. I practice safety that is why the car has been parked for almost a year now.  I will not drive it until this issue is resolved the right way.
I have a brake vacuum kit to assist with the bleeding of the lines.
I have a software to run diagnostics on the car I will see if it has the ABS troubleshooting.
I will try as you recommended. Thanks again, like I said earlier specialized is hard to find.
I appreciate the time you took to help me.??
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
