Tailshaft bushes and centre bearing was fine, torqued up all suspension and steering nuts and bolts under the car
Need to go to the drags again and see how it goes at higher than Hwy speeds now (over 80mph)
I will get all my wheels rebalanced first
Hopefully around mid December
  • Like 1
So, after alot of googling the vibration "may" be coming from the transmission
"Apparently" vibrations in a 4l60e can happen at higher speeds if the line pressure isn't right, which is what's happing
So, as the trans was due for a service in Jan 23 anyway, it has been booked in for the service at Craigs Automatics, while it's there they said they will look at the tune and see if they can "page up" the line pressure a bit in the old slush box
Next run at WSID is hopefully 21 Dec 22
  • Like 1
Purchased one of those brake bleeders that connects to my air compressor....... "where have you been all my life"
After putting it up on stands and removing the wheels a full brake flush took no more than 5 minutes, nice
Then....whilst it was up there.....
Ended up going OCD and gave at undercarriage a full power wash, sprayed everything with silicone spray, and then wiped it all down, now all the bits that you cannot see look so shiny and purdy....LOL
The interior then copped a full detail with the bissell spot cleaner and steamer, the interior looked pretty good before I started, but the manky water that the bissell sucked out proved other wise, but it has been 12 months since the bissell last seen any action inside the car
The engine bay is next, well tomorrow, for a detail, followed by exterior washing and waxing all ready for a cruise down to Goulburn on Thursday for my daughters attestation at the police academy on Friday
My daughter has asked me to wear my service dress, and Jackie has grabbed a fancy outfit for the occasion, the car will be on point like it is on a military style "boots and saddle parade".....so.....
Weather warning: you just know it is going to be pissing down in the Southern Tablelands on Thursday and Friday, and they will probably want me to park in some unsealed carpark....LOL
  • Like 1
Which model of the bissell steam cleaner are you using? Is it one of those you can get at supercheapauto?
I quite like the idea of doing that to get 20+ years of gunk out of the carpets in the car. Have been holding off though as I wasn't sure whether the "cheapy" ones would be any good.
Yeap, that's the one
I use it around the house on small spills and stuff as well
If you haven't "wet vacced" the seats or carpet for 20 years you will definitely need to give it a few goes
Be prepared to change water that looks like diarrhoea
  • Thanks 1
Haha, see how it goes! Good to know that it works out alright. Don't know if it has been that long, but I wouldn't be surprised. The cabin filters certainly looked like it when I replaced them.
Will keep an eye on supercheapauto and wait for a sale.
  • Like 1
I have a bissel thingy but yet to actually try it on car, or carpets. Not really sure why as I recently cleaned the car.. and carpets. Could use it on door inserts too. Pretty easy to remove the rear seat out of the car too. In short, I have been lazy.
Thankyou for mentioning this vaccum brake bleeder thing, now that I know that exists my life is 4% improved.
  • Haha 1
Got the transmission serviced today at Craigs and talked about the vibration, found what is causing my vibration at speed, the Tuff mounts
The ones I have have the red poly in them, so pretty firm, under load at speeds over 100 mph harmonics from the engine are transferring the engine harmonics through the K frame sending the vibration to to the steering rack and body
They recommend that I go back to rubber if I want to get rid of it, they also said that it isn't a issue, apart from the NVH, as I need lower engine mounts that the OEM rubber ones for bonnet clearance that unfortunately isn't a option
It is apparently a common issue with hard poly and solid engine mounts in some cars, he had red Tuff mounts in his 1200hp Skyline and had the same issue, same same for some of the drag cars he works on
Tuff mounts do a black poly that is softer and would be a little better but as it only happens at the drags, from 100mph - 124 mph, I probably won't swap them out
I other news we want down to Goulburn to watch my daughters Assentation, parked up in the police academy and proceeded to have "all" of the police checking out the car, luckly the all agreed it was a nice build, a little loud, but nothing that would cause them concern
I did feel like a rabbit in a spot light for a while though
  • Like 2
lol driving into the lion's den!
sounds like you should have bought a nissan v8 not a holden. Cima came with active engine mounts so as not to trouble Japanese execs with such things.
  • Haha 1
The standard holden mounts were fine, until I put thermal spacers under the blower and the bonnet wouldn't close
The clearance issue was temporarily fixed with the reverse cowl bonnet, but, it took 2 weeks before I hated the look of it
Meh, first world modification problems
And yes, "driving into the loins den" is exactly how it felt...🤣
1 hour ago, GTSBoy said:
Is that because they're a bunch of pricks?
LOL, where's spell check when you need it
As for pricks, yeah nah, I've only been hassled by the police when I've done something stupid, getting pinned for an illegally modified car for example is a fair cop in my opinion
I've got alot of cop mates, and my daughter is now one, they do a hard thankless job, and in reality, if you don't do stupid stuff, or blatantly break the law they leave you alone
There job is to enforce the law, whether or not I agree with the laws means nothing
They are the ones who stand between you and the crazy taking the fire
RIP to the 2 young QLD cops that were set up and assassinated by mentally deficient lunatics
RIP to the neighbour who went to see if the mentally deficient lunatics needed help, only to be killed for his neighbourly  good deed
Police are like soldiers, nobody loves them until the enemy is at the gate
  • Like 2
45 minutes ago, GTSBoy said:
Yeah, I was aware of the daughter and other cop friend link. I was sticking it to you for your possible Freudian slip!
Yeah, it's cool man, I've seen and heard about the stuff they go through on a nearly daily basis, first responders see the worst of people, and people at their worst time, like MVA, murders, assaults, suicides and the like
I've seen some pretty horrific stuff, and been in the odd sticky predicament, but nothing like the saturation they deal with, like ambos and fire fighters, it is a real common occurrence and a head f#ck
I am sometimes to quick to judge and go partial retard  when people go on about the police, sometimes a joke triggers me
Meh, love you long time
  • Like 1
Yep. I am of similar thinking.
Imagine how shit or off the rails your day has gone for you to dial 000 for Fire, Ambo, or Police.
That's their entire work day.
Every single day.
  • Like 1
Finally stuck the new head lights in
Just need to go to the "big warehouse" at work, turn off the lights in the warehouse and align them better
They are level, but probably not at the correct height or centred correctly
  • Like 1
The Mrs commented that there was a little drone on the Hwy in cruise doing 110, I never noticed it, but meh, I got the local exhaust shop that built my exhaust to throw in a resonator
Space was limited, so they fabricated a custom little 12" x 4" in and out, round resonator with a 5" body that fits like a glove
I'll need to wait till we go for a cruise this weekend and see if she even notices, but, it has smoothed out the "rage" from the exhaust at WOT, it isn't exactly quiter, it has just lowered the tone down a bit, I actually think it sounds better now
And it didn't cost a thing, winning....I love free stuff
  • Like 1
Full wash, wax and detail, so you know it's going to rain this weekend when me and the Mrs go for a cruise to Robertson pie shop
Also removed the sub, amp and associated wiring from the boot of the car
The aftermarket Pioneer head unit and speakers are sweet anyway, the sub just made stuff rattle, I forgot how much room for activities the boots in these things have
I've also decided to further investigate the vibration I get at the drags over 100 mph, it will be getting the driveshaft reconditioned and rebalanced with new uni joints, center bearing and couplings
In other Mrs related news, the car is still to loud for her liking when starting it in the morning ( #because the neighbours), "sigh", so I am contemplating getting a 4" Varex oval muffler for the rear, wired im to a momentary switch, when it is closed I'm hoping she stops breaking my balls, when it is open, I assume it will probably be louder
Hardy Spicer in Moorebank did a reco on my tailshaft so it is now back to new....OEM spec IRT couplings, uni's and centre bearing (that puppy was trashed), it is all balanced up and within specs........soooo......
I'm going to WSID tomorrow to see how it likes some tailshaft speed
They said due to the power I'm making the front and rear OEM style couplings probably won't last to long if I'm launching it hard with drag radials, and if I'm doing alot of high tailshaft speed runs (read: at the big end at the drags) the centre bearing will also not be enjoying life
A fancy new 3" 2 piece tailshaft with super dooper big uni's and some special centre bearing that can cope with all of the rpm's and all of the killerwaps is apparently only $2.5k away, so as my max rpm is only 6k rpm, that is an over engineered option available for when I chew out my new OEM spec one
Also purchased a killer wickerwork picnic basket for when we go on country adventures, this will work well with my 12v fridge to keep all the fruits, cheeses, sangas and vino chilled
  • Like 2
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
