hey guys a couple of questions
1. Would i be correct in saying that the Apex'i Power FC D Jetro version uses a map sensor instead of AFMs?
2. Is anyone running one of these at the moment? pros/cons?
3. For the guys who have build big power RB26s what brand pistions and rods have you guys used? And what would you recommend for an RB26 running twin garrett 3040s.
thanks heaps guys
anf
https://www.sau.com.au/forums/topic/48010-rb26-power-fc-forgies-etc/
cant help ya wth your first 2 questions, but as far as piston and rod brands go, with pistons you cant go too wrong with any of the "known" brands; JE, Arias, CP, ACL (Ross, re-branded), etc, i've had experience with all these and all have proved good, personally i dont like wiseco, i think their design is not as good as the others, but thats my opinion. As far as rods go Argo are good, Crower do a really nice rod, and well priced, Carrillo also do awesome gear. Probabley comes dowm to how deep your pockest are. But all of these, i've had experience with, and should take good power
dont need to win the lotto ive been saving for 3 years and ive had heaps of help from my old man and my uncles.
ive also had alot of luck so far with once in a life time deals when buying things for the car. only thing holding me back atm is which parts to use, not money.
im building a show/drag car, so the budget is really the last thing on my mind.
ive sacrificed alot of things to raise the money for this car.
i cant believe things are actually starting to happen :)
Guest two.06l
Hi anf
we have just done what u are starting, it was great, the pride and satisfaction of doing it yourself, in your own shed is worth all the pain. We are really pleased with how the car looks and runs. We used Aries pistons and had the skirts teflon coated and a cryogenic treatment done to all engine parts (to make stronger/last longer, mainly for drag). Rods? don't know/forget, and the engine builder is not here to ask. I can pm you a summary sheet of the things we have done to the car if you want?
Cheers, hope you accept advice/comments from a girl?
  • 1 year later...
It allows the removal of the Air Flow Meters which is particularly advantageous for large turbo applications such as the TRUST T88, HKS T517Z or twin GT3540's etc.... drag setups.
I've heard it also uses an ignition cut for the rev limiter instead of a fuel cut (which the STD Power FC uses) but I'm not sure if that's true or not.
If you want a Power FC for a road car I don't think it's overly necessary unless your idea of a road car to strap the biggest turbo on you can think of. For most people who don't upgrade the turbo or only upgrade slightly to keep good engine response and minimal lag, the STD Power FC will be sufficient.
apparently there arent that many people who can tune the d-jetro properly and it takes a shit load longer to tune.
im using arias pistons and REV billet rods with arp bolts.
also if your looking at getting an N1 oil pump you may want to just upgrade to a 33 gtr crank as the pump driver is smaller on the 32gtr crank
with those size turbo's you might be better looking at a stroker kit, HKS 2.8 - OS Giken 3.0l - Trust 2.7 litre kit, as a 2.6 with those size turbo's is going to have to be one hell of a revver to make use of the power band.
I also heard, yet again, that Apexi was no longer..... anyone else heard this???
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
