silviaz Posted June 14, 2020 Share Posted June 14, 2020 I'm curious if after you over rev a car and break a rocker arm, can the valve stem seal get damaged in the process, letting oil into the combustion chamber? Or can a bent valve after a broken rocker arm be bent in a way that allowed oil to pass through? Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/ Share on other sites More sharing options...
GTSBoy Posted June 14, 2020 Share Posted June 14, 2020 If you think about the violent thrashing of broken parts between the cam lobe and the valve while it's all flailing away at "over rev" speeds...... Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7932991 Share on other sites More sharing options...
Ben C34 Posted June 14, 2020 Share Posted June 14, 2020 Yes Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7932995 Share on other sites More sharing options...
KiwiRS4T Posted June 14, 2020 Share Posted June 14, 2020 Valve stem seal is the least of your worries at this point... Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7932999 Share on other sites More sharing options...
silviaz Posted June 14, 2020 Author Share Posted June 14, 2020 3 hours ago, KiwiRS4T said: Valve stem seal is the least of your worries at this point... Whys that? whats the biggest concern? Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7933022 Share on other sites More sharing options...
silviaz Posted June 14, 2020 Author Share Posted June 14, 2020 4 hours ago, GTSBoy said: If you think about the violent thrashing of broken parts between the cam lobe and the valve while it's all flailing away at "over rev" speeds...... that makes sense, metal shards flying everywhere, scratching cam shafts lobes and stuff. Do slightly scratched camshaft lobes matter too much? or is it fine as long as the cam lobe can spin freely without getting caught up? Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7933024 Share on other sites More sharing options...
Rusty Nuts Posted June 14, 2020 Share Posted June 14, 2020 1) Yes of course any damage to the cam lobe surface will cause damage/wear to all other parts it is in contact with. 2) Yes of course breaking a rocker arm can/will bend a valve stem 3) Yes of course a bent valve stem can cause a valve stem seal to leak, or crack a valve guide. Didn't you get this car originally with a broken rocker arm? Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7933042 Share on other sites More sharing options...
silviaz Posted June 15, 2020 Author Share Posted June 15, 2020 10 hours ago, Rusty Nuts said: 1) Yes of course any damage to the cam lobe surface will cause damage/wear to all other parts it is in contact with. 2) Yes of course breaking a rocker arm can/will bend a valve stem 3) Yes of course a bent valve stem can cause a valve stem seal to leak, or crack a valve guide. Didn't you get this car originally with a broken rocker arm? Hey thanks for that, and yes to your question. Link to comment https://www.sau.com.au/forums/topic/480601-can-broken-rocker-arms-damage-valve-stem-reals/#findComment-7933111 Share on other sites More sharing options...
