Hey Guys,
Some more threads of interest to those wanting to know more about Ceffys and other nissan sedans with a bit of grunt or those wanting to compare there mods or see what bang for buck people are getting for their buck.
Same as the other sticky threads NO COMMENTS or SPAM in this thread, this is purely to post your Dyno Sheets. Any comments or questions can be made in HERE
This is the format they should be in:
Car:
Engine:
Power:
Performance Mods: (ie. clutch, turbos, exhausts...)
Dynoed: (where)
When:
Mode:
And attach or insert a pic of the dyno sheet.... do not post if you dont have a dyno sheet.
https://www.sau.com.au/forums/topic/48064-show-us-what-ya-got-dyno-sheets/
  • Replies 42
Car: A31 Cefiro
Power: Approx 330rwkw
Engine: Rb26DETT
Mods: RB36DETT swap, 8l sump, 600cc injectors, A/m cams, HKS adjustable cam gears, Custom turbos - equivilant to hi flo 2540s, Hybrid bar and plate cooler, twin 3" exhaust, Nismo fuel pressure regulator, HKS 1 bar wastegate actuators, Wolf3dV4 running MAP.
Dyno run info: performed at SST in Perth in shootout mode(accredited), restricted to 1 bar boost, rich tune. Tune has since been leaned out a touch but have not got a chart for that run.
Car: A31 Cefiro
Engine: RB26DETT
Mods: RB26DETT, Custom turbos - equivilant to hi flo 2540s, HKS adjustable cam gears, A/m cams, nismo fuel pressure regulator, Bosch 040 pump, 600cc injectors, twin 3" exhaust, Wolf3dV4, Hybrid bar and plate cooler, 8L sump.
Needs: Forged internals
Dyno run info: Performed at SST in Perth in shootout mode, running 1bar boost pressure.
Car: R31 Skyline GTSII
Engine: RB30ET
Power: Approx 253rwkw
Mods: VLT T3/4 Hiflow Turbo, Wolf 3Dv4, full 3" mandrel system, JPC Cam, Bosch 036 injectors, Bosch Motorsport fuel pump, Large IC.
Acheived on SST dyno Perth, in Shootout mode on 14psi
Never mind the HP look at the torque :D
  • 3 weeks later...
Car: CA31 88 Cefiro.
Engine: RB20DET
Power: ahhh, read the sheet...
Mods: bleedvalve 12psi, 32psi fuel pressure (which as you can see = bit too rich) 3 1/2inch??? exaust, ceramic clutch, Jun lightweight fly wheel, pod, bit of 3inch bit of pipe up to pod, dodgyish catch can. I think thats the most of it.
Where: Murcry Motorsports SAU dyno day, so on dyno dynamics shootout mode.
RUN DONE IN 4th GEAR!!!
  • 1 month later...
Car: a31
Engine: sr20det
Power: 190rwkw @ 13-14psi
Performance Mods: greddy t518z turbz, GTR intercooler, z32 afm, walbro 255lt/hr fuel pump, 550cc injectors, remapped ECU, pod+cai+heatshield, twin-thingy dumppipe to 3 or 3.5".... etc..
Dynoed: Unique AutoSports
When: 10/10/04
Mode: I don't know - it says shootout mode but doesn't have the "shootout 04" logo everyone else seems to have
ok heres mine:
Car: a31
Engine: RB26DETT
Power: 207rwkw @ 9psi with 472nm Torque
Performance Mods: Std Cooler, Std Turbos, 3" Straight Pipe Catback, Blitz SUS Mesh Pods
Dynoed: XTC Performance, Coburg
When: 10/10/0
When: 23/10/04
  • 4 weeks later...
  • 2 years later...
Car- 88 a31
engine- r32 rb20det
power- 170rwkw @11psi falling down to 9.5 by redline.
mods- 3" turbo back zorst no mufflers or cat, HKS mushroom filter, gtr fmic & impul chipped ecu, suspicions on the possibility of cams due to the very stong top end power. and high power figure.
Edited by r31et
Car: R32 Skyline - 4 Door
Engine: RB20DET
Power: 196rwkw @ 12psi
Performance Mods: GTR fuel Pump, R34 Turbo, 3inch Cat back, Extreme Clutch, FMIC, Lighten Flywheel, K@N Air Filter,
Dynoed: In Malaga
When: About 6 Months ago
Engine: RB20DET
Power: 150.2 rwkw @ 14PSI
Performance Mods: GTR fuel Pump, Stock turbo, 3" Cat Back Exhaust , FMIC, Blitz SSBC, Apexi Pod
Dynoed: Morpowa in SA
When: Fri 14th Sep.
Have either a rooted Crank angle sensor or a dead knock sensor.
GAY.
So more once i got those looked at
Hey this is off topic but i have a couple of spare Crank angle sensors for a RB20 silvertop (old type and new), if you want you can borrow one off me to test it on your car to see if it fixes the problem, i also have some spare knock sensors too but i doubt it would be that (my car has had bad knock sensors for ages).
By the way i was the dude in the pearl white ceff with the vented front guards at Mallala accross from you on Saturday, i was behind you in a couple of runs and you were doing really well
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
