@GTSBoy I’ll be honest with you I’m not sure at all.. your right I should probably look into it.. just asking in general because I’m intrested in throwing in a turbo and like I said not looking for god knows how much power just more then I have now an slowly build up with the turbo
4 minutes ago, JohnnyR31Silo said:
Iv been looking around found one on market place he reckons it came off a Jeep commander an reckons it’ll be good for a r31 but I’m not sure which is why I’m showing you guys
You do not want that turbo. It appears to be all sorts of silly. Funky exhaust inlet flange, possibly crazily small compressor.
What you want is a VL Turbo type turbo. Something with a T3 inlet, sensibly arranged to sit on a stock VL turbo manifold with the inlets and outlets facing in the right directions. An RB25 or VG30 turbo would also be appropriate.
Edited by GTSBoy
Thank you man I really do appreciate thats basically what I was trying to ask like how you said “rb25” “vg30” like I knew for a vl motor, because Rb30 because Iv changed the motor it’s a Holden  Rb30 Not a Nissan
if you would pick which one will be the best for my car which one would you pick?
because I do want the car to last me you know iv spent some money on it already an willing to spend abit more but I don’t want to look after it an keep it for a very long time I’m not looking to thrash into a pole
I wouldn't even bother asking that question until you work out whether you need to spend another $5k on engineering before you'd even be allowed to do it.
I'm in SA. We have it much better than the Nazi state that you live in. But even here it is strictly illegal to just throw a turbo onto a car. You must get approval from Regency (our Vicroads) before you start, and they will demand engineering where it is needed, and I'm pretty sure that turboing a vehicle that never had a turbo variant will require engineering.
  • Thanks 1
@GTSBoy okay sweet as I’ll do some more research like I said before I really do appreciate you taking the time to help me out.. I’ll look into it more I’ll do more research into VicRoads and what not and speak to my mechanic
if there’s any other tips or advice you can give me I would appreciate it thanks heaps my bro
Read Kinkstah's thread re: engineering a car to give you some idea. I think its a headache and not worth spending that cash on your 31. I'd save the pennies if you're that keen and buy a 33 and work on that. Or save for a deposit on a house and just enjoy your car the way it is until you get more experienced on the roads. My 2c.
  • Like 1
I’ll see if I can have a look at the build tho
another question I have is does anyone know any good alarm systems and central locking that’s compatible with the r31? Not looking to spend heaps but I don’t want to make it harder (knock on wood) for the car to get stolen
Any alarm at all. Anything with a snake name. Anything from Jaycar. Anything from almost anywhere so long as it isn't the cheapest, nastiest 3rd shift China-Bay spec.
It's not like car alarm technology has actually moved along in any meaningful way in the last 20 years. Remote start and pagers and all that stuff are just fairy floss window dressing. The alarm needs to have black wires, sufficient relay interlocking to properly immobilise the vehicle and the right combination of sensors for your purposes. A tilt switch for example, to help with tow truck style thieves.
And a 120+dB siren, in the cabin.
  • Like 1
  • Thanks 1
@GTSBoy
yeah I was looking on eBay but I don’t really trust them tbh... was calling up Autobarn and Supercheap repco an what not but they couldn’t really recommend one I’ll try give them another call tomorrow
iv never heard of jay car but I’ll give them a call first thing tomorrow to have a look an I’ll tell them what you said with the immobiliser an what not, I definitely want a loud siren just in case they do try steal it so I can hear it... I’m gonna throw in a kill switch as well might be going overboard but I love this car an I’m not gonna let anyone take it if I can help it
Found a place to fit an alarm system I’ll be getting it done next week
another question my cluster the original one I had the fuel played up an odometer didn’t work
bought a new one and everything works Except the fuel gauge and Oil plays up which is shit iv heard that you can get these things called odometer COG SPEEDO GEAR SUITS for Holden commies just wondering if there’s any way I can fix the fuel gauge and the oil without having to buy another cluster an hope for the best cheers
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
