Hello to all!  My name is Tim and I recently imported an R32 GTR from Japan.  I am a lifelong car enthusiast and, like many enthusiasts my age, the Skyline has been a dream car since my Gran Turismo gaming days.  I have already spent countless hours reading through this forum, and I will continue to do-so, but I created this profile so I can be a contributor as well.  Hopefully a good one.  Cheers!
  • Like 3
https://www.sau.com.au/forums/topic/480917-newb-from-maryland-usa/
1 hour ago, Matty George said:
Hey man congratulations on the purchase. Nothing like a pure white GTR32. I have one as well exactly the same. Enjoy the ride and the moding journey. The cash goes pretty quick but the car goes even quicker??
You're not kidding. I'm learning that lesson very quickly - spun a bearing after less than 500 miles of driving.  ?
56 minutes ago, Matty George said:
Holy shit that’s no good. What are your plans with the car in the future
It's at a shop now in queue for the teardown, and it has quickly turned into one of those "since the motor is out" situations.  But if I'm going spend the money to rebuild the motor I should do it properly, right?  Forged internals, addressing the oiling issues, block brace, -5's, fuel, clutch, etc., etc.
26 minutes ago, Ben C34 said:
The front differential is integrated into the sump and, at higher HP levels, the twisting force can cause the block to flex and potentially crack. The brace is a billet girdle that reinforces the button end to prevent the twisting/cracking.  Mine is from JHH Racing.
1 hour ago, Old man 32 GTR said:
I’m guessing PRP block brace? -5’s are nice if you want to stay twins, but since it’s out... a single turbo conversion with a precision 64/66 would be even nicer. ?
welcome aboard
I did give some consideration to a single turbo setup. No question they make power more efficiently, but I'm happy with a mild build at this point.  Also, retaining a fairly stock appearance is appealing to me so I decided to stick with the low mount twins. The forged internals and brace leave me the option to go nuts if I ever change my mind down the road. But that's assuming my wife let's me have access to the savings account again....
Welcome dude! I just popped up here recently as I’m a new Skyline owner myself. I’m in VA, but grew up in MD. What part of MD, if you don’t mind me asking?
Edited by LiteraCola
Haha I grew up in Virginia but moved to Maryland two years ago. I'm in Southern Maryland, Hughesville area.  You're just over the Harry Nice then, right?
Edited by Cones
Haha yes sir! Nice to see another skyline owner  so close! I’m over in MD a lot since I work over there, and my family is still there.
  • Like 1
Very cool! I've seen two R32's in Waldorf within the last two months, and a close friend of mine has a 32 and a 35, so there are a few in the area. We'll have to do a meet-up/cruise when I get my car back. Hopefully by end of September.
Sounds good man, let me know! Ive seen about the same amount here, but still no 33’s (which I secretly like) haha. There’s a dude out in Fredericksburg with a 32gtr that goes by Goodezilla on YouTube. His car is supposedly pretty badass, like 600+whp. I think he’s part of a Skyline group of some kind, maybe 5 or 6 cars, all 32’s.
I used to keep up on that shit on FB, but I’ve been social media-free for a few months now. I’m a little out of the loop now haha
23 minutes ago, True Slide said:
Maryland is fairly close to me. Im in central nj and in September there will be a 2nd annual skyline meet if your interested
Will this be in Jersey? Can you PM me some information about this? Thanks
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
