It just reduces the chance of rattling springs. Race only stuff generally just uses a flat spring with flat spring mount, even then, they aren't generally noisy unless the spring is not captive through full travel
If it is a stock form spring going into the stock spring seat, but without the rubber insulator, then it will likely be quite a lot noisier. This from the generous contact area of a stock form spring up against the large diaphragm of the perch.
If the spring is lowered & stiffer, that loss of 10mm or so of installed compression may make it just possible for the spring to become non-captive at full droop, which will probably be fine 99.99% of the time but every now and then it is a recipe for disaster.
I hear a knock every now and then when going over kerb to park so think it is the spring not resting on the pad
i am thinking of hooking up the spring compressor and hammer it so spring sits on the pad
is that a bad idea?
2 minutes ago, GTSBoy said:
If you have spring compressors, then take the extra 15 minutes to jack the car up and remove the suspension unit. Dismantle it and put it back together properly.
It's only going to take 15 minutes.
You are right
it is a nightmare to get it off though. Will probably do that
I'm not sure what you are talking about. 1 bolt at the bottom. 2 at the top. I can get the front out of my car in about 4 minutes or the back out in slightly longer because the top bolts are harder to reach. And then it just falls out of the car.
  • 1 month later...
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
