19 minutes ago, GTSBoy said:
Bright dash lights are horrible. Are you sure you want to go down this path?
Yes, I even want to cancel the dimmer(dims when you turn the lights on) on my defi gauges and on my stereo. Does anybody know how to cancel the dimmer on the stereo? And with defi gauges, which of the 4 wires do I delete? Cheers
Just disconnect the stereo's wire that connects to the dashlighting power. All it does is sense that the lights are powered and dim the stereo accordingly.
You should be able to find the equivalent wire on the Defis by just probing them with the lights on and off. Whichever one goes hot with the lights on is the culprit.
Do you know which colour wire that is to save me time? Also can I probe it when the key is out but the light is on? Will the wire still be hot?( defi only turns on when key is in Accessory)
No. I assume you're talking about the Defis, as I have even less idea what stereo you're talking about!
As to the Defis, still no, because I don't have any. But probing for voltage will take 2.1 seconds.
And yes, the wire that you're looking for will be hot when the dashlights are on, and not when the dashlights are off. This has nothing to do with the ignition position, or key in/out, because the lights can be turned on regardless of ignition.
Just for clarity - the wire we're looking to probe for voltage when the lights are on is not hot because of the Defis, it is hot because it is the connected to the lighting circuit of the car. That's how the Defis sense the lights are on. They're just looking for voltage on that line too. They're not actually using the power on that wire to do anything except decide that the lights are on.
Ok so the defi lights will only turn on, dim or not, when the key is on accessory. But if I turn the lights on from my stalk, key out, the defi dimmer wire will still be hot?IIRC the defi is actually bridged to the climate control, but that’s irrelevant
The denominations you're listing sound like bulb sizes, not necessarily brightness.
Either way, you don't want to find the brightest bulb. Have you ever ridden a car in the night with a really bright dash? You will not be able to see outside at night. Also, the bulb may be bright but if it only shines one direction the bleeding from one area on your dash/cluster to another will be obvious and this does not look good. You'll want to find a bulb with true 360 degree coverage or diffusion to not make the bleeding so obvious.
He's talking about the actual LED chips that are on the "bulbs". 3030, 3528, 5630 etc are the chip types, and some are brighter than others, because of physical size or current handling capacity or simply improved (newer) spec.
All such LED dash bulbs are set up to give "even" illumination distribution. As even as they can be, anyway.
But otherwise I agree with your comment. Bright dash lights suck nuts.
  • Like 1
Bright dash lights are a bad idea for night driving if you care about being able to see at night. I've heard arguments that it helps to keep drivers from dozing off but if you're so close to falling asleep that a bit of blue light makes the difference you shouldn't be driving.
Hey guys I figured that 3030 SMD is among the brightest led you can get. But now there’s the question to whether to get COB or SMD. After much contemplation I decided with SMD because they are brighter but COB apparently has a cleaner and crisper light and has a diffuser.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
