Hi All,
My car have been sitting for years with fuel in the tank and the fuel actually smells pretty bad..
Has anyone cleaned out their fuel tank before? or know of any places that can clean it? I got a quote from a place and they said $399 to get the tank cleaned lol
Any help/recommendation would be highly appreciated.
Thanks
https://www.sau.com.au/forums/topic/481287-gtr-r32-fuel-tank-cleaning/
Yep I have cleaned multiple fuel tanks as I have cracked a 32 GTR fuel tank more than once. You're talking about the molasses like shit left from unleaded fuel right ? No, unleaded will not move it like you would think. After much trial and error -
Bleach. Doesn't react with the HDPE the plastic tank is made out of. The bleach bottles are made out of the same material. Get about 8 - 10 litres, leave overnight. Swirl and agitate next day as required. It will bring it back to new.
  • Like 1
39 minutes ago, BK said:
Yep I have cleaned multiple fuel tanks as I have cracked a 32 GTR fuel tank more than once. You're talking about the molasses like shit left from unleaded fuel right ? No unleaded will not move it like you would think. After much trial and error -
Set for it, thanks mate ??
  • Like 1
Fully serious. Test it on a gummy hose clamp or something else from your tank. It will strip the crap off everything. Obviously make sure your tank is pressure washed afterwards and left to dry, as the last thing you want in your fuel system is bleach. Results may vary depending on the crud in your tank, might need more but it's a good start with 8lt and will 100% work. Please post results for confirmation as I've seen no one recommend it before and has proven for me to be the only sure way that works. If you can seal the tank and invert it even better, as getting it off of the bulkhead area is the hardest part. Good round up weed killer substitute afterwards.
  • 4 weeks later...
Hi mate,
Here's the results and the process;
1) Empty the old fuel and dispose
2) Degrease the fuel tank inside out
3) Pressure wash is multiple times
4) I put in 12l of bleach and shake the fuel tank to make sure it reaches everywhere
5) Left it overnight and came back the next day and pressure washed it again, and again and again lol
6) Air dryed
7) Cleaned the outside of the tank and give it a fresh coat of satin black paint
  • Like 1
  • 2 years later...
Many thanks @BK!
Put in 10L of bleach, sloshed it around every now and again over 24 hours. Pressure washed it after draining the bleach out. Not perfect, but massive improvement and happy with the results. Pics below, the tank was still wet when I took the before and after shots.
Before:
After:
  • Like 1
On 13/01/2023 at 1:19 PM, Zurlox said:
Many thanks @BK!
Before:
After:
No worries, good job. If you persisted for days you would've got that solid stuff off but it does look pretty caked on. Might have needed to use a solvent for that last bit then rebleach to get it 100%
Looks good anyway 👍
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
