Hi guys new here, just purchase a 1984 Nissan 300c at a good price.
I'm chasing a set of inner/outer tie rod ends which seems to be a hard task here in Tasmania
I've google online which has been a nightmare, as most places want the OEM number but they only list the Nissan Cedric/gloria (Japanese naming of the car).
and I'm not sure if parts are correct.
Do you guys know of someone here in Australia that I can get parts for my Nissan or even import them for me?
Thank you in advance
David
Edited by wokko 300c
https://www.sau.com.au/forums/topic/482013-nissan-300c/
2 hours ago, wokko 300c said:
mm, so how do we get parts fr our Nissan 300C then, do I literally ask Nissan Japan for Nissan 300C parts ???
6 hours ago, GTSBoy said:
Given that the 300C was fully imported, there is absolutely no chance that the parts to suit the Jap models won't fit.
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947780
Yes, get in touch with someone like Jesse Streeter with your Vin. He can source from nissan or probably find aftermarket alternative.
If you can have the car off the road, the other option is a friendly repco....if you can measure up everything you will almost certainly find aftermarket to fit.
BTW, nice buy, I guess there aren't too many of those parked in your street
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947783
No, any local dealer should be able help with your VIN/chassis number available.    300C = Y30 in Nissan model 'speak', so either the FAST or E-FAST parts systems will tell you the Nissan PN's needed.     E-FAST is for older Nissan models that Nissan has 'dropped' from the 'main' FAST system.    Anyway, attached is a screenshot of a quick search I did on E-FAST.   Ignore the CA20S line.....that engine was not used in this model in Australia, we got the VG30 version.     These PN's should (must...) be checked with Nissan using your VIN.     My versions of FAST and E-FAST are also a bit on the old side, so there may well be PN supersessions or worse (hopefully not)
A quick check on Amayama suggests prices are up around $150 each (I didn't check them all though) , but that's genuine parts so probably not unexpected.
I'd be surprised if these parts aren't available aftermarket (Repco/Bursons/etc....but some of these guys no nothing about anything older than 10 or 20 years unless it's a Holden, Ford, etc).   There's also ebay, but that can be a lottery.   These cars use a fairly common (for the day) steering box/drag link/idler arm steering arrangement so parts may well be similar to 240C and similar sedans.
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947790
Thanks guys for your suggestion
I've tried nissan and they can only get drivers side which will cost me >$500 which I can't afford
I've tried repco burson  peddars and all the auto places around Tassy but all say that nothing is listed
My chassis number is CHN 087491 if someone can help
not sure if nissan cedric y30 6 gen parts would fit my car ????
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947799
Well there's these that supposedly fit a 1984 300C according to the compatibility list:
https://www.ebay.com.au/itm/2x-Brand-New-OEM-QUALITY-Steering-Tie-Rod-Ends-For-NISSAN-LAUREL-C31/153729447915?fits=Model%3ADatsun+300C&hash=item23cafd37eb:g:OwEAAOSw8A1d0lnH
....but this is only the outer joint, there's also an inner as well (one each side - see previous parts screen shot).
Sold as a pair because one will be LH thread, the other RH thread (also the reason Nissan PN's are different side to side). Ditto for the inner joint.
The other possibility is to contact a specialist Nissan wrecker who sometimes also stock new aftermarket parts.
BTW, that's not a chassis number....should have 'Y30' in it somewhere.   Check the firewall or the ADR (compliance) plate.   Compliance plate should look something like this (but this is for an 84 N12 Pulsar):
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947806
Thanks guys for all the help, finally today after numerous random emails a bloke from Melbourne sourced 3 of the tie rods from japan for me $282.65 to front door and I found the fourth one on ebay for $30 rhs inner.
Hopefully they all are correct (touch wood)
https://www.sau.com.au/forums/topic/482013-nissan-300c/#findComment-7947881
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
